• Hardware Platform (Jetson / GPU) Jetson Orin Nano Dev kit • DeepStream Version 7.0 • JetPack Version (valid for Jetson only) 6 • TensorRT Version 8.6.2 • Cuda Version 12.2
I’m facing a problem with trying to do live-time inference with cameras videos. I am trying to use peoplesegnet to inference people segmentation and also trying to track them with nvmultiobjecttracker.so.
The main issue is that when I run my pipeline with the inference model and the nvTracker I get a huge delay, about 4s delayed between the live frame and the displayed frame by the pipeline. I’m trying to reduce this delay and I noticed that when I turn off Inference and Tracking the delay drops to a non-significant delay, my doubt is that does all this latency between frame and reality comes from those 2 sections from my pipeline?
Yes, I know that. My question is about the delay between the frame and the real time frame, what is the correlation of gpu usage and the delay?
I am using right now a jetson orin nano and I can get 8fps. But if I run with a different gpu like a jetson agx orin I get 22fps but the delay stills over there
I’m using peoplesegnet with int 8 quantization
(PeopleSegNet | NVIDIA NGC) because from what I have seen it looks like the best model considering accuracy and performance(framerate). Is there a better optimization that I could do or another model to try to see if gpu is the main source of the bottleneck from the pipeline?
