I am looking at getting a dell system and replacing its graphics card with GTX 280. Is dell precision T7400 compatible with GTX 280 in terms of power supply, dimensions, cooling etc? Is there any other dell system (cheaper the better) that will work?
i seriously advise not gettign a dell end pc, why not buy a prebuilt pc that comes with a gtx 280 and not waste money on a card you will remove? better yet just build your own pc, we can help you with the specs it will have adequate power etc
It’d be helpful if you posted the specs of the dell here, rather than making us dig around for them.
Even then it may be difficult to really say. The PC manufacturers usually don’t advertise things like power supply. My gut feeling is that most, if not all, Dell factory power supplies will be underpowered for a GTX280.
Yeah, I know :)…Unfortunately I work for a company that does not allow to buy assembled machines. I need to go to a branded vendor, preferrably Dell :(
980W should be more than enough for 1 GTX280. (Probably enough for two, in fact, but sizing up a PSU is a bit tricky.) How much does this thing cost?
Try finding the user manual. That should have a lot of details. However, top-end cards like a GTX280 are pretty standard hardware and Dell would get a lot of angry calls if most of their PCs didn’t support them.
Ask Dell !
I mean that seriously. If the workstation is not indented to hold a big GPU it may not fit (at least not with replacing the cooling and maybe other stuff).
They often use BTX mainboard with own cooling solutions, a simply spec investigation (e.g. voltage,slots,etc) might not be enough !
I have a Dell T7400 and it works fine with a GTX 280, although you will need a 6pin to 8pin power adapter( it is sometimes provided with the card package).
It was also discussed here :
Dell will apparently be offering Tesla cards as options for their machines soon (January according to the Dell product guy). This would probably imply their top end machines have power supplies and cooling to cope. Well worth giving them a call though.
If you can use something other than Dell (ie not company purchasing policy etc) then its worth constructing your own. Then you can get exactly what you want in terms of motherboard / power / cooling.
Dell is already offering machines wtih GTX280s. Why not get those?
EDIT: Or rather, find a Dell that supports GTX280 as an option, buy it, and and then buy the card yourself. (Also buy extra ram and your own monitor… Dell overcharges for all of these)
Thanks a lot guys for your comments. Yes, I am planning to buy a dell machine (T7400) and add in a GTX 280 card or a quadro FX 5800 (which is much more expensive). These are much more expensive than assembled machines, but I am kind of restrained by company policy :(.
