Hello NVIDIA world.
I’ve just installed Fedora 30 on a Dell Precision 7530 laptop. It seems to have two graphic chips… one embedded in the cpu and a quadro.
[root@ncidellprec ~]# lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation Device 3e94
01:00.0 VGA compatible controller: NVIDIA Corporation GP104GLM [Quadro P3200 Mobile] (rev a1)
I was able to install the nvidia driver and it seems like the nvidia driver is loaded
root@ncidellprec ~]# lsmod | grep -i nvidia
nvidia_drm 53248 0
nvidia_modeset 1114112 1 nvidia_drm
nvidia 18812928 21 nvidia_modeset
ipmi_msghandler 73728 2 ipmi_devintf,nvidia
drm_kms_helper 212992 2 nvidia_drm,i915
drm 491520 4 drm_kms_helper,nvidia_drm,i915
but when I try and run the nvidia-settings program, I get the following
ERROR: Unable to load info from any available system
I’ve uploaded the debug report file.
any thoughts?
nvidia-bug-report.log.gz (1.05 MB)
the reason I’m posting this error, is that I believe it related to other errors. For example, there is a gnome shell extension which plots the GPU usage. It doesn’t work. Another gnome shell extension shows the current temperature of the GPU, it also does not work. so there is some basic problem in accessing the GPU on the Dell Precision 7530.
thanks.
It’s an Optimus notebook, the internal display is connected to the intel gpu but you’re using the ‘nomodeset’ kernel parameter which kills the igpu so nothing works. Please remove that parameter, then configure the notebook to use prime:
[url]https://github.com/wildtruc/nvidia-prime-select[/url]
manual config:[url]https://devtalk.nvidia.com/default/topic/1022670/linux/official-driver-384-59-with-geforce-1050m-doesn-t-work-on-opensuse-tumbleweed-kde/post/5203910/#5203910[/url]
Hi Generix,
I installed nvdia-prime-select and issued the command
sudo nvidia-prime-select nvidia
It all went fine. A message said I needed to logout for the change to take effect, so I rebooted instead.
On reboot, the gdm login display failed to show up.
attached is the bug report log file.
nvidia-bug-report.log.gz (1.12 MB)
It looks like the nvidia-prime script didn’t have any effect, also seems to be quite outdated. So let’s push it it a bit. Please create /etc/X11/xorg.conf.d/11-nvidia-prime.conf with contents
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "PrimaryGPU" "Yes"
Option "AllowEmptyInitialConfiguration" "true"
EndSection
and create two files optimus.desktop in /etc/xdg/autostart/ and /usr/share/gdm/greeter/autostart/ containing
[Desktop Entry]
Type=Application
Name=Optimus
Exec=sh -c "xrandr --setprovideroutputsource modesetting NVIDIA-0; xrandr --auto"
NoDisplay=true
X-GNOME-Autostart-Phase=DisplayServer
I did as you suggested.
[root@ncidellprec ~]# cat /etc/X11/xorg.conf.d/11-nvidia-prime.conf
Identifier "nvidia"
Driver "nvidia"
EndSection
[root@ncidellprec ~]# cat /etc/xdg/autostart/optimus.desktop
[Desktop Entry]
Type=Application
Name=Optimus
NoDisplay=true
[root@ncidellprec ~]# cat /usr/share/gdm/greeter/autostart/optimus.desktop
[Desktop Entry]
Type=Application
Name=Optimus
NoDisplay=true
And the bugfile is attached…
nvidia-bug-report.log.gz (1.17 MB)
There is a nice explanation of the optimus laptop configuration at the following link
[url]https://www.dell.com/community/XPS/Hybrid-vs-Optimus-Graphics/td-p/5707715[/url]
As it turns out, I can turn off the intel GPU and have the Quadro GPU do all the work in the Bios. The nvidia driver then works fine.
the only bit I don’t like about the laptop is that the CPU’s run rather hot. On my desktop, they are running at 33 deg C while on the laptop it’s closer to 60… I’m wondering if running in dual iGPU and dGPU mode may reduce some of the processing overhead to cool down the PC a bit. But for now I’m good to go.
One bit which does not work is the screen backlight intensity control. I’ll post another topic on that problem later. It’s not so urgent.
