**• Hardware Platform (Jetson / GPU)**RTX3080
• DeepStream Version6.4
I am using deepstream-app for one video analytics monitoring project.
I have a few queries for that.
(1)We are using deepstream-app as background service running. It is run using a bash file from crontab in linux.
So we need to log errors in application as well as customized logging into the same log file. How can I produce log file for deepstream-app?
Since the application will run long time like a week or so, so that log file should not grow too big. Is there a proper way of logging in deepstream-app?
(2)Yesterday tested deepstream-app in one scenario.
The scenario is that one of rtsp sources is unplugged intentionally.
The program starts and crushed after a few iterations of run.
How can I prevent program crush? The program should continue run for other sources. Pls see in the attached image.
(3)In one test scenario, the application is running. Then unplugged one source. The application try to reconnect a few times and give up. I set big number for rtsp-reconnect-attempts in source configuration as
rtsp-reconnect-interval-sec=10
#Limit the rtsp reconnection attempts
rtsp-reconnect-attempts=10000
But still give up after a few runs. I think there is a default number for rtsp-reconnect-attempts.
