Deploying Custom segmentation model to deepstream-test5
• Hardware Platform (Jetson / GPU):
nvidia-smi
Thu Mar 7 20:21:59 2024
| NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 44C P0 N/A / 80W | 6MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2904 G /usr/lib/xorg/Xorg 4MiB |
• DeepStream Version:6.2
We had trained an custom Pytorch model using the below repository
We are able to successfully run the model and observe inference outputs using both .pth and .onnx formats outside of DeepStream. However, when we attempt to integrate the ONNX model with the DeepStream SDK 6.2 as the primary GIE in the deepstream-test5-app, although the ONNX to TensorRT engine conversion occurs without issues and the application runs, we do not see any inference results in the output. Additionally, when we enable the Kafka sink, the application fails. We would appreciate your support in resolving these issues to successfully port our model to the DeepStream test application. We have attached all the necessary files in the below link for you to replicate the scenario as well the the weight files.
You can refer to the example below.
deepstream-segmentation-test
In addition, you can read the part about NvDsInferSegmentationMeta in the document. nvinfer will put the inference results into the metadata.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvinfer.html
sorry for the long delay. If you want to use unet, here is an official sample for reference.
