I don’t know how to implement the model in DeepStream.
Can you help me? Thanks so much.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I trained unet model. My weight file format is .tlt, But in example unet in “Deepstream_tao_apps”, I saw tlt-encoded-model format is .etlt.
I try export .tlt model to .etlt model with code below:
!tao unet export
-e $SPECS_DIR/unet_train_resnet_unet_isbi.txt
-m $EXPERIMENT_DIR/isbi_experiment_unpruned/weights/model_isbi.tlt
-o $EXPERIMENT_DIR/isbi_experiment_unpruned/model_isbi.etlt
-k $KEY
But when I run “./apps/tao_segmentation/ds-tao-segmentation configs/app/seg_app_unet.yml”. I got an error
After train, I export model weight .tlt to .etlt follow:
!tao unet export
–engine_file $EXPERIMENT_DIR/isbi_experiment_unpruned/model_isbi.engine
–gen_ds_config
-k $KEY
I setup file pgie_unet_tao_config.yml:
property:
gpu-id: 0
net-scale-factor: 0.007843
model-color-format: 1
offsets: 127.5;127.5;127.5
labelfile-path: unet_labels.txt
##Replace following path to your model file
model-engine-file: ../../models/unet/model_isbi.engine #current DS cannot parse onnx etlt model, so you need to #convert the etlt model to TensoRT engine first use tao-convert
tlt-encoded-model: ../../models/unet/model_isbi.etlt
tlt-model-key: tlt_encode
infer-dims: 3;320;320
batch-size: 1
0=FP32, 1=INT8, 2=FP16 mode
network-mode: 1
num-detected-classes: 2
interval: 0
gie-unique-id: 1
network-type: 2
output-blob-names: softmax_1
segmentation-threshold: 0.0
##specify the output tensor order, 0(default value) for CHW and 1 for HWC
segmentation-output-order: 1
DeepStream can not work without TensorRT. Are you working with DeepStream docker container? Please check the device or environment which you want to run DeepStream on.
