The GMSL to CSI-2 deserialser IC (MAX96712) mentioend in Xavier sereis camera module hardware design guide has gone obsolete. The other deserialiser IC (MAX9296A) as mentioned in the below link is also obsolete. https://ic.maximintegrated.com/GMSL
Can someoen suggest a suitable replacement of MAx96712/MAX9296A that can be used with AGX Xavier platform and L4T?
We are desiging a custom carrier card. The carrier card will have the GMSL to CSI-2 deserialiser. I am referring to the camera module reference design guide and see the recommendation to use MAX96712. I am not getting the datasheet and other details for this IC. Can you recommend any other deserialser IC which can be used with AGX Xavier? I am specifically looking forward to use a device for which the driver is supported with L4T.
