UPDATE: the new stable prod driver release 570.124.04 fixed all the main issues (1-3) listed below for me. The generic card name output (issue 4-6) remains, but is non-critical for me. nvidia-smi now lists the card just fine:
| NVIDIA-SMI 570.124.04 Driver Version: 570.124.04 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5070 Ti Off | 00000000:0A:00.0 On | N/A |
| 0% 40C P8 25W / 300W | 2147MiB / 16303MiB | 1% Default |
| | | N/A |
Initial post below, for future reference:
I’m aware of how fresh this card is, however, the current beta driver 570.86.16 doesn’t seem to really support this card despite its claims. I’m encountering the following issues after switching to the 5070 TI from an AMD 6650 XT:
- JetBrains IDEs (Goland, PyCharm, IntelliJ) became unusable, selecting text, executing runs, just using the UI became unbearably slow, with any action in the UI mentioned above cranking up GPU utilization to 100 %. VS code does not exhibit this slowdown to make it unusable, but even just typing in the editor gets the GPU utilization to 60 %. Typing text in Chrome (editing this post) even gets the GPU up to 86 %…).
- Games are unplayable, Doom Eternal and Helldivers 2 ~ 15 fps @ WQHD, Unigine Heaven benchmark @ ~ 27 fps, some games crash outright when trying to start (Total War: Warhammer II)
nvidia-smioutput, the GPU name isn’t even pretending to be referring to the 5070 TI:
| NVIDIA-SMI 570.86.16 Driver Version: 570.86.16 CUDA Version: 12.8 |
| | | MIG M. |
| 0 NVIDIA Graphics Device Off | 00000000:0A:00.0 On | N/A |
| 0% 42C P8 26W / 300W | 1190MiB / 16303MiB | 0% Default |
| | | N/A |
fastfetchsystem details, also same generic GPU name reference:
OS: Fedora Linux 41 (KDE Plasma) x86_64
Kernel: Linux 6.13.4-200.fc41.x86_64
Display (DELL G2724D): 2560x1440 @ 165 Hz in 27" [External] *
Display (DELL G2724D): 1440x2560 @ 165 Hz in 27" [External]
DE: KDE Plasma 6.3.1
WM: KWin (Wayland)
CPU: AMD Ryzen 9 5950X (32) @ 5.08 GHz
GPU: NVIDIA Device 2C05 (VGA compatible)
Memory: 9.75 GiB / 125.69 GiB (8%)
Swap: 0 B / 8.00 GiB (0%)
lspcioutput following suit:
❯ lspci | grep VGA
0a:00.0 VGA compatible controller: NVIDIA Corporation Device 2c05 (rev a1)
lsmodoutput (nouveauis not loaded):
❯ lsmod | grep nvidia
nvidia_uvm 4145152 0
nvidia_drm 147456 181
nvidia_modeset 2138112 83 nvidia_drm
nvidia 13074432 1526 nvidia_uvm,nvidia_modeset
drm_ttm_helper 16384 1 nvidia_drm
video 81920 2 asus_wmi,nvidia_modeset
I have not yet tried any CUDA workloads on it, which was the initial purchase argument for this card…
Is there an ETA for a driver version that’s supposed to truly support this card?
