I’m trying to get Detectron2 working in a container on my Jetson Nano.
On the host, /etc/nv_tegra_release contains:
# R32 (release), REVISION: 5.0, GCID: 25531747, BOARD: t210ref, EABI: aarch64, DATE: Fri Jan 15 22:55:35 UTC 2021
My Docker container is using a matching tag as recommended.
My Dockerfile currently looks like this:
FROM nvcr.io/nvidia/l4t-ml:r32.5.0-py3
ENV DEBIAN_FRONTEND noninteractive
RUN apt-get update && apt-get install -y \
python3-opencv ca-certificates python3-dev build-essential git wget sudo ninja-build libopenblas-base libopenmpi-dev
# create a non-root user
ARG USER_ID=1000
RUN useradd -m --no-log-init --system --uid ${USER_ID} appuser -g sudo
RUN echo '%sudo ALL=(ALL) NOPASSWD:ALL' >> /etc/sudoers
USER appuser
WORKDIR /home/appuser
ENV PATH="/home/appuser/.local/bin:${PATH}"
RUN wget https://bootstrap.pypa.io/get-pip.py && \
python3 get-pip.py --user && \
rm get-pip.py
RUN pip install --user cmake # cmake from apt-get is too old
# Detectron2
RUN sudo apt install -y libjpeg-dev zlib1g-dev
RUN git clone https://github.com/facebookresearch/detectron2.git
RUN pip install -e detectron2
However it fails at the detectron2 installation with:
Obtaining file:///home/appuser/detectron2
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/home/appuser/detectron2/setup.py'"'"'; __file__='"'"'/home/appuser/detectron2/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-jv51b9d7
cwd: /home/appuser/detectron2/
Complete output (11 lines):
File "<string>", line 1, in <module>
File "/home/appuser/detectron2/setup.py", line 10, in <module>
import torch
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 189, in <module>
_load_global_deps()
File "/usr/local/lib/python3.6/dist-packages/torch/__init__.py", line 142, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
Some searching suggests libcurand requires CUDA version 10, which I assume I don’t have? However I have seen successful builds so not sure where I’m going wrong.
Any help is much appreciated!
