I want to install detectron2 on jetson nano.
My specifications are :
- L4T 32.5.1 [ JetPack 4.5.1 ]
- Ubuntu 18.04.5 LTS
- Kernel Version: 4.9.201-tegra
- CUDA 10.2.89
- CUDA Architecture: 5.3
- OpenCV version: 4.1.1
- OpenCV Cuda: NO
- CUDNN: 8.0.0.180
- TensorRT: 7.1.3.0
- Vision Works: 1.6.0.501
- VPI: ii libnvvpi1 1.0.15 arm64 NVIDIA Vision Programming Interface library
- Vulcan: 1.2.70
- Torch version 1.7
I also tried building with torch version 1.9, but still no luck. I have to specify that I installed torch from the wheels provided at PyTorch for Jetson
This is the full installation log:
python3 -m pip install 'git+https://github.com/facebookresearch/detectron2.git'
Defaulting to user installation because normal site-packages is not writeable
Collecting git+https://github.com/facebookresearch/detectron2.git
Cloning https://github.com/facebookresearch/detectron2.git to /tmp/pip-req-build-f872qzl6
Running command git clone -q https://github.com/facebookresearch/detectron2.git /tmp/pip-req-build-f872qzl6
Resolved https://github.com/facebookresearch/detectron2.git to commit de6416be86155111e05ee102702c55470f7450c6
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests<3,>=2.21.0->tensorboard->detectron2==0.5) (2018.1.18)
Collecting oauthlib>=3.0.0
Using cached oauthlib-3.1.1-py2.py3-none-any.whl (146 kB)
Building wheels for collected packages: detectron2, matplotlib, termcolor
Building wheel for detectron2 (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"'; __file__='"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-khx532gs
cwd: /tmp/pip-req-build-f872qzl6/
Complete output (372 lines):
running bdist_wheel
/home/jetson/.local/lib/python3.6/site-packages/torch/utils/cpp_extension.py:339: UserWarning: Attempted to use ninja as the BuildExtension backend but we could not find ninja.. Falling back to using the slow distutils backend.
warnings.warn(msg.format('we could not find ninja.'))
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/detectron2
copying detectron2/__init__.py -> build/lib.linux-aarch64-3.6/detectron2
creating build/lib.linux-aarch64-3.6/tools
copying tools/lazyconfig_train_net.py -> build/lib.linux-aarch64-3.6/tools
copying tools/analyze_model.py -> build/lib.linux-aarch64-3.6/tools
copying tools/__init__.py -> build/lib.linux-aarch64-3.6/tools
copying tools/plain_train_net.py -> build/lib.linux-aarch64-3.6/tools
copying tools/lightning_train_net.py -> build/lib.linux-aarch64-3.6/tools
copying tools/visualize_data.py -> build/lib.linux-aarch64-3.6/tools
copying tools/visualize_json_results.py -> build/lib.linux-aarch64-3.6/tools
copying tools/train_net.py -> build/lib.linux-aarch64-3.6/tools
copying tools/benchmark.py -> build/lib.linux-aarch64-3.6/tools
copying tools/convert-torchvision-to-d2.py -> build/lib.linux-aarch64-3.6/tools
creating build/lib.linux-aarch64-3.6/detectron2/engine
copying detectron2/engine/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/engine
copying detectron2/engine/hooks.py -> build/lib.linux-aarch64-3.6/detectron2/engine
copying detectron2/engine/defaults.py -> build/lib.linux-aarch64-3.6/detectron2/engine
copying detectron2/engine/launch.py -> build/lib.linux-aarch64-3.6/detectron2/engine
copying detectron2/engine/train_loop.py -> build/lib.linux-aarch64-3.6/detectron2/engine
creating build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/memory.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/env.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/visualizer.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/analysis.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/collect_env.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/comm.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/video_visualizer.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/registry.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/file_io.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/serialize.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/testing.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/colormap.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/logger.py -> build/lib.linux-aarch64-3.6/detectron2/utils
copying detectron2/utils/events.py -> build/lib.linux-aarch64-3.6/detectron2/utils
creating build/lib.linux-aarch64-3.6/detectron2/checkpoint
copying detectron2/checkpoint/catalog.py -> build/lib.linux-aarch64-3.6/detectron2/checkpoint
copying detectron2/checkpoint/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/checkpoint
copying detectron2/checkpoint/c2_model_loading.py -> build/lib.linux-aarch64-3.6/detectron2/checkpoint
copying detectron2/checkpoint/detection_checkpoint.py -> build/lib.linux-aarch64-3.6/detectron2/checkpoint
creating build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/aspp.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/rotated_boxes.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/wrappers.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/mask_ops.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/batch_norm.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/roi_align_rotated.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/deform_conv.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/shape_spec.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/roi_align.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/blocks.py -> build/lib.linux-aarch64-3.6/detectron2/layers
copying detectron2/layers/nms.py -> build/lib.linux-aarch64-3.6/detectron2/layers
creating build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/torchscript_patch.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/flatten.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/caffe2_patch.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/torchscript.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/api.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/c10.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/shared.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/caffe2_inference.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/caffe2_modeling.py -> build/lib.linux-aarch64-3.6/detectron2/export
copying detectron2/export/caffe2_export.py -> build/lib.linux-aarch64-3.6/detectron2/export
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo
copying detectron2/model_zoo/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo
copying detectron2/model_zoo/model_zoo.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo
creating build/lib.linux-aarch64-3.6/detectron2/projects
copying detectron2/projects/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/projects
creating build/lib.linux-aarch64-3.6/detectron2/solver
copying detectron2/solver/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/solver
copying detectron2/solver/build.py -> build/lib.linux-aarch64-3.6/detectron2/solver
copying detectron2/solver/lr_scheduler.py -> build/lib.linux-aarch64-3.6/detectron2/solver
creating build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/catalog.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/detection_utils.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/dataset_mapper.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/benchmark.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/build.py -> build/lib.linux-aarch64-3.6/detectron2/data
copying detectron2/data/common.py -> build/lib.linux-aarch64-3.6/detectron2/data
creating build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/lvis_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/panoptic_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/coco_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/evaluator.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/rotated_coco_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/cityscapes_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/fast_eval_api.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/testing.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/sem_seg_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
copying detectron2/evaluation/pascal_voc_evaluation.py -> build/lib.linux-aarch64-3.6/detectron2/evaluation
creating build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/image_list.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/rotated_boxes.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/boxes.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/masks.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/instances.py -> build/lib.linux-aarch64-3.6/detectron2/structures
copying detectron2/structures/keypoints.py -> build/lib.linux-aarch64-3.6/detectron2/structures
creating build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/instantiate.py -> build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/compat.py -> build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/config.py -> build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/lazy.py -> build/lib.linux-aarch64-3.6/detectron2/config
copying detectron2/config/defaults.py -> build/lib.linux-aarch64-3.6/detectron2/config
creating build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/test_time_augmentation.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/poolers.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/matcher.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/mmdet_wrapper.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/anchor_generator.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/sampling.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/box_regression.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
copying detectron2/modeling/postprocessing.py -> build/lib.linux-aarch64-3.6/detectron2/modeling
creating build/lib.linux-aarch64-3.6/detectron2/data/transforms
copying detectron2/data/transforms/augmentation.py -> build/lib.linux-aarch64-3.6/detectron2/data/transforms
copying detectron2/data/transforms/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/data/transforms
copying detectron2/data/transforms/transform.py -> build/lib.linux-aarch64-3.6/detectron2/data/transforms
copying detectron2/data/transforms/augmentation_impl.py -> build/lib.linux-aarch64-3.6/detectron2/data/transforms
creating build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/coco.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/builtin_meta.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/builtin.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/coco_panoptic.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/lvis_v1_categories.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/pascal_voc.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/lvis_v0_5_categories.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/cityscapes_panoptic.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/cityscapes.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/register_coco.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
copying detectron2/data/datasets/lvis.py -> build/lib.linux-aarch64-3.6/detectron2/data/datasets
creating build/lib.linux-aarch64-3.6/detectron2/data/samplers
copying detectron2/data/samplers/grouped_batch_sampler.py -> build/lib.linux-aarch64-3.6/detectron2/data/samplers
copying detectron2/data/samplers/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/data/samplers
copying detectron2/data/samplers/distributed_sampler.py -> build/lib.linux-aarch64-3.6/detectron2/data/samplers
creating build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/rcnn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/panoptic_fpn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/retinanet.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/build.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
copying detectron2/modeling/meta_arch/semantic_seg.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/meta_arch
creating build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/regnet.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/resnet.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/backbone.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/build.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
copying detectron2/modeling/backbone/fpn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/backbone
creating build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/rotated_fast_rcnn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/mask_head.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/roi_heads.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/keypoint_head.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/box_head.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/fast_rcnn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
copying detectron2/modeling/roi_heads/cascade_rcnn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/roi_heads
creating build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
copying detectron2/modeling/proposal_generator/rrpn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
copying detectron2/modeling/proposal_generator/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
copying detectron2/modeling/proposal_generator/rpn.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
copying detectron2/modeling/proposal_generator/build.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
copying detectron2/modeling/proposal_generator/proposal_utils.py -> build/lib.linux-aarch64-3.6/detectron2/modeling/proposal_generator
creating build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/mask_head.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/config.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/roi_heads.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/point_head.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/point_features.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/color_augmentation.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
copying projects/PointRend/point_rend/semantic_seg.py -> build/lib.linux-aarch64-3.6/detectron2/projects/point_rend
creating build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/config.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/build_solver.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/resnet.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/semantic_seg.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/lr_scheduler.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
copying projects/DeepLab/deeplab/loss.py -> build/lib.linux-aarch64-3.6/detectron2/projects/deeplab
creating build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/config.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/__init__.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/dataset_mapper.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/post_processing.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/target_generator.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
copying projects/Panoptic-DeepLab/panoptic_deeplab/panoptic_seg.py -> build/lib.linux-aarch64-3.6/detectron2/projects/panoptic_deeplab
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs
copying detectron2/model_zoo/configs/Base-RetinaNet.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs
copying detectron2/model_zoo/configs/Base-RCNN-FPN.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs
copying detectron2/model_zoo/configs/Base-RCNN-C4.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs
copying detectron2/model_zoo/configs/Base-RCNN-DilatedC5.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_DC5_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_DC5_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/rpn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_101_DC5_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/retinanet_R_101_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_101_C4_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_X_101_32x8d_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/fast_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/rpn_R_50_C4_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_C4_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_101_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_C4_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/retinanet_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/faster_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Detection/retinanet_R_50_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-Keypoints/keypoint_rcnn_R_50_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-Keypoints/keypoint_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-Keypoints/keypoint_rcnn_R_101_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-Keypoints/Base-Keypoint-RCNN-FPN.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-Keypoints/keypoint_rcnn_X_101_32x8d_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Cityscapes
copying detectron2/model_zoo/configs/Cityscapes/mask_rcnn_R_50_FPN.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Cityscapes
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation/mask_rcnn_X_101_32x8d_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation/mask_rcnn_R_101_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation/mask_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv0.5-InstanceSegmentation
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_FPN_1x_giou.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_101_DC5_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_101_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_X_101_32x8d_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_DC5_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_C4_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_101_C4_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_C4_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_DC5_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/fast_rcnn_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/retinanet_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_C4_GCV_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/keypoint_rcnn_R_50_FPN_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/panoptic_fpn_R_50_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/retinanet_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/rpn_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/semantic_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/cascade_mask_rcnn_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_C4_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/cascade_mask_rcnn_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/keypoint_rcnn_R_50_FPN_normalized_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_FPN_pred_boxes_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_FPN_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_C4_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/rpn_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/keypoint_rcnn_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/fast_rcnn_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/semantic_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/semantic_R_50_FPN_training_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/panoptic_fpn_R_50_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/keypoint_rcnn_R_50_FPN_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_C4_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_DC5_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/mask_rcnn_R_50_FPN_instant_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
copying detectron2/model_zoo/configs/quick_schedules/panoptic_fpn_R_50_inference_acc_test.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/quick_schedules
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
copying detectron2/model_zoo/configs/COCO-PanopticSegmentation/panoptic_fpn_R_101_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
copying detectron2/model_zoo/configs/COCO-PanopticSegmentation/Base-Panoptic-FPN.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
copying detectron2/model_zoo/configs/COCO-PanopticSegmentation/panoptic_fpn_R_50_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
copying detectron2/model_zoo/configs/COCO-PanopticSegmentation/panoptic_fpn_R_50_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/PascalVOC-Detection
copying detectron2/model_zoo/configs/PascalVOC-Detection/faster_rcnn_R_50_C4.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/PascalVOC-Detection
copying detectron2/model_zoo/configs/PascalVOC-Detection/faster_rcnn_R_50_FPN.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/PascalVOC-Detection
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mask_rcnn_R_50_FPN_1x_dconv_c3-c5.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/scratch_mask_rcnn_R_50_FPN_9x_gn.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/scratch_mask_rcnn_R_50_FPN_3x_gn.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/panoptic_fpn_R_101_dconv_cascade_gn_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mask_rcnn_R_50_FPN_3x_gn.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/cascade_mask_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/scratch_mask_rcnn_R_50_FPN_9x_syncbn.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mask_rcnn_R_50_FPN_1x_cls_agnostic.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/semantic_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mask_rcnn_R_50_FPN_3x_syncbn.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mask_rcnn_R_50_FPN_3x_dconv_c3-c5.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/cascade_mask_rcnn_R_50_FPN_3x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/cascade_mask_rcnn_X_152_32x8d_FPN_IN5k_gn_dconv.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Detectron1-Comparisons
copying detectron2/model_zoo/configs/Detectron1-Comparisons/keypoint_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Detectron1-Comparisons
copying detectron2/model_zoo/configs/Detectron1-Comparisons/faster_rcnn_R_50_FPN_noaug_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Detectron1-Comparisons
copying detectron2/model_zoo/configs/Detectron1-Comparisons/mask_rcnn_R_50_FPN_noaug_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Detectron1-Comparisons
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv1-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv1-InstanceSegmentation/mask_rcnn_X_101_32x8d_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv1-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv1-InstanceSegmentation/mask_rcnn_R_101_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv1-InstanceSegmentation
copying detectron2/model_zoo/configs/LVISv1-InstanceSegmentation/mask_rcnn_R_50_FPN_1x.yaml -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/LVISv1-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-Detection/retinanet_R_50_FPN_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Detection
copying detectron2/model_zoo/configs/COCO-Keypoints/keypoint_rcnn_R_50_FPN_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-Keypoints
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_FPN_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_R_50_C4_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_regnetx_4gf_dds_fpn_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-InstanceSegmentation/mask_rcnn_regnety_4gf_dds_fpn_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-InstanceSegmentation
copying detectron2/model_zoo/configs/COCO-PanopticSegmentation/panoptic_fpn_R_50_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/COCO-PanopticSegmentation
copying detectron2/model_zoo/configs/Misc/torchvision_imagenet_R_50.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
copying detectron2/model_zoo/configs/Misc/mmdet_mask_rcnn_R_50_FPN_1x.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/Misc
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_50_FPN_400ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_101_FPN_100ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnetx_4gf_dds_FPN_100ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_101_FPN_200ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnetx_4gf_dds_FPN_200ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_50_FPN_200ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_50_FPN_100ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnetx_4gf_dds_FPN_400ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_101_FPN_400ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_R_50_FPN_50ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnety_4gf_dds_FPN_100ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnety_4gf_dds_FPN_200ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
copying detectron2/model_zoo/configs/new_baselines/mask_rcnn_regnety_4gf_dds_FPN_400ep_LSJ.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/new_baselines
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common
copying detectron2/model_zoo/configs/common/optim.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common
copying detectron2/model_zoo/configs/common/coco_schedule.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common
copying detectron2/model_zoo/configs/common/train.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/mask_rcnn_c4.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/mask_rcnn_fpn.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/panoptic_fpn.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/retinanet.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/keypoint_rcnn_fpn.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
copying detectron2/model_zoo/configs/common/models/cascade_rcnn.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/models
creating build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/data
copying detectron2/model_zoo/configs/common/data/coco.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/data
copying detectron2/model_zoo/configs/common/data/coco_keypoint.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/data
copying detectron2/model_zoo/configs/common/data/coco_panoptic_separated.py -> build/lib.linux-aarch64-3.6/detectron2/model_zoo/configs/common/data
running build_ext
building 'detectron2._C' extension
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/tmp
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/ROIAlignRotated
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/nms_rotated
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/box_iou_rotated
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/cocoeval
creating build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/deformable
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DWITH_CUDA -I/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc -I/home/jetson/.local/lib/python3.6/site-packages/torch/include -I/home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include -I/home/jetson/.local/lib/python3.6/site-packages/torch/include/TH -I/home/jetson/.local/lib/python3.6/site-packages/torch/include/THC -I/usr/local/cuda-10.2/include -I/usr/include/python3.6m -c /tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/vision.cpp -o build/temp.linux-aarch64-3.6/tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/vision.o -DTORCH_API_INCLUDE_EXTENSION_H -DTORCH_EXTENSION_NAME=_C -D_GLIBCXX_USE_CXX11_ABI=1 -std=c++14
In file included from /home/jetson/.local/lib/python3.6/site-packages/torch/include/ATen/Parallel.h:149:0,
from /home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include/torch/utils.h:3,
from /home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include/torch/nn/cloneable.h:5,
from /home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include/torch/nn.h:3,
from /home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/csrc/api/include/torch/all.h:12,
from /home/jetson/.local/lib/python3.6/site-packages/torch/include/torch/extension.h:4,
from /tmp/pip-req-build-f872qzl6/detectron2/layers/csrc/vision.cpp:3:
/home/jetson/.local/lib/python3.6/site-packages/torch/include/ATen/ParallelOpenMP.h:84:0: warning: ignoring #pragma omp parallel [-Wunknown-pragmas]
#pragma omp parallel for if ((end - begin) >= grain_size)
aarch64-linux-gnu-gcc: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
error: command 'aarch64-linux-gnu-gcc' failed with exit status 4
ERROR: Failed building wheel for detectron2
Running setup.py clean for detectron2
Building wheel for matplotlib (setup.py) ... done
Created wheel for matplotlib: filename=matplotlib-3.3.4-cp36-cp36m-linux_aarch64.whl size=9965679 sha256=de334bf3f3c91bd222fead3bfe86521ca841f15577f1ab0f7bfe293633f44b04
Stored in directory: /home/jetson/.cache/pip/wheels/09/f4/84/841a4c463638ce3204dcb7137673efe82f22fba82544946b1f
Building wheel for termcolor (setup.py) ... done
Created wheel for termcolor: filename=termcolor-1.1.0-py3-none-any.whl size=4847 sha256=0d06d3a825c321096b6676e0c1fe2f72bc0de341d1b9568b72005970af6905a4
Stored in directory: /home/jetson/.cache/pip/wheels/93/2a/eb/e58dbcbc963549ee4f065ff80a59f274cc7210b6eab962acdc
Successfully built matplotlib termcolor
Failed to build detectron2
Installing collected packages: pyasn1, charset-normalizer, zipp, rsa, requests, pyasn1-modules, oauthlib, cachetools, requests-oauthlib, pyyaml, pyparsing, portalocker, kiwisolver, importlib-metadata, google-auth, cycler, antlr4-python3-runtime, yacs, werkzeug, typed-ast, toml, termcolor, tensorboard-plugin-wit, tensorboard-data-server, tabulate, regex, pathspec, omegaconf, mypy-extensions, matplotlib, markdown, iopath, importlib-resources, grpcio, google-auth-oauthlib, click, appdirs, absl-py, tensorboard, pydot, pycocotools, hydra-core, fvcore, cloudpickle, black, detectron2
WARNING: The script normalizer is installed in '/home/jetson/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
WARNING: The scripts pyrsa-decrypt, pyrsa-encrypt, pyrsa-keygen, pyrsa-priv2pub, pyrsa-sign and pyrsa-verify are installed in '/home/jetson/.local/bin' which is not on PATH.
WARNING: The script tabulate is installed in '/home/jetson/.local/bin' which is not on PATH.
WARNING: The script markdown_py is installed in '/home/jetson/.local/bin' which is not on PATH.
WARNING: The script google-oauthlib-tool is installed in '/home/jetson/.local/bin' which is not on PATH.
WARNING: The script tensorboard is installed in '/home/jetson/.local/bin' which is not on PATH.
WARNING: The scripts black, black-primer and blackd are installed in '/home/jetson/.local/bin' which is not on PATH.
Running setup.py install for detectron2 ... /
error
command: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"'; __file__='"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-4jsrjq9e/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/jetson/.local/include/python3.6m/detectron2
running install
running build
running build_py
creating build
running build_ext
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"'; __file__='"'"'/tmp/pip-req-build-f872qzl6/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-4jsrjq9e/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/jetson/.local/include/python3.6m/detectron2 Check the logs for full command output.
