dev driver install with linux kernel 3.0 fails
Not able to install the ‘devdriver_4.0_linux_64_270.41.19’ package on a gentoo system with kernel version 3.0.0; previous and current versions of the standard driver (‘NVIDIA-Linux-x86_64-280.13’) install without a hitch.
Installation syntax attempted…
sh devdriver_4.0_linux_64_270.41.19.run --kernel-output-path /lib/modules/3.0.0-gentoo/build --kernel-install-path /lib/modules/3.0.0-gentoo/kernel/drivers/video --kernel-source-path /lib/modules/3.0.0-gentoo/source -e
resulting error log…
-> Installing NVIDIA driver version 270.41.19.
-> There appears to already be a driver installed on your system (version: 280.
   13).  As part of installing this driver (version: 270.41.19), the existing d
   river will be uninstalled.  Are you sure you want to continue? ('no' will ab
   ort installation) (Answer: Yes)
-> No distribution pre-install script found.
-> No precompiled kernel interface was found to match your kernel; this means
   that the installer will need to compile a new kernel interface.
-> Checking development tools:
-> found `cc` : `/usr/bin/cc`
-> found `make` : `/usr/bin/make`
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> Using the kernel source path '/lib/modules/3.0.0-gentoo/source' as specified
   by the '--kernel-source-path' commandline option.
-> Kernel source path (Answer: '/lib/modules/3.0.0-gentoo/source')
-> Using the kernel output path '/lib/modules/3.0.0-gentoo/build' as specified
   by the '--kernel-output-path' commandline option.
-> Kernel source path: '/lib/modules/3.0.0-gentoo/source'
-> Kernel output path: '/lib/modules/3.0.0-gentoo/build'
ERROR: If you are using a Linux 2.4 kernel, please make sure
       you either have configured kernel sources matching your
       kernel or the correct set of kernel headers installed
       on your system.
If you are using a Linux 2.6 kernel, please make sure
       you have configured kernel sources matching your kernel
       installed on your system. If you specified a separate
       output directory using either the "KBUILD_OUTPUT" or
       the "O" KBUILD parameter, make sure to specify this
       directory with the SYSOUT environment variable or with
       the equivalent nvidia-installer command line option.
Depending on where and how the kernel sources (or the
       kernel headers) were installed, you may need to specify
       their location with the SYSSRC environment variable or
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
-> No distribution failed-install script found.
with no special install syntax, the error log is such
-> License accepted.
-> Kernel module installation path (Answer:
   '/lib/modules/3.0.0-gentoo/kernel/drivers/video')
-> Kernel module installation path: /lib/modules/3.0.0-gentoo/kernel/drivers/vi
   deo
       on your system.
       the equivalent nvidia-installer command line option. etc.. etc..
Just for fun I’ve tried setting the SYSOUT and SYSSRC env vars to no avail.
Has anyone enjoyed installing the dev driver onto a linux kernel 3.0 platform successfully?
Have you solved this issue?
I am using the x11-drivers/nvidia-drivers-275.09.07 and sys-kernel/gentoo-sources-3.0.6 which runs fine on my Gentoo. Also a gentoo ebuild for the 270.41.19 driver is available, so why not using on of them instead of the package you mentioned?
Best Regards
Marius
