The issue here is I’ve been using the ros_serial_arduino package to exchange data between my arduino nano and jetson orin agx dev kit.
So initially i tested the communication using USB Serial (/dev/ttyUSB0), and the expected behaviour is that the arduino resets every time I initiate communication(i.e while i run the ros_serial node) on the jetson.
But while using the GPIO UART header (ie /dev/ttyTHS0), the communication does work fine as expected, but the arduino does not get reset while I initiate communication (ie while i run the ros_serial node). Even the ros service ~/reset_arduino, does not do anything to the arduino when connected to /dev/ttyTHS0, but does work when the arduino is connected via USB (/dev/ttyUSB0)
As far as my research, I suspect it has something to do with the setting of DTR bit, which triggers the reset of the arduino.
I’ve seen in this thread that Arduino’s are supposed to reset when a serial port is opened, which also happens with the jetson if the nano is connected via USB serial to the jetson. I’ve also read something about DTR, and the arduino waiting for a new sketch to be uploaded during serial comm init, but i’m unable to find the ref. I’m just guessing here.
No I have not verified loopback test, kindly guide me through it. Also what commands do i use for the dmesg info you asked.
