I’m trying to send and receive data to and from a microcontroller connected to the Jetson Nano’s TX and RX pins. RX seems to work fine, but TX is very unreliable. The connected device will receive incorrect data most of the time (e.g. getting 208 or 130 instead of 1). I tried decreasing the baud rate from 115200 to 9600, which helped somewhat, but the device is still receiving incorrect data a large portion of the time. I’ve disabled nvgetty and ModemManager. When I use a USB to Serial adapter, the problem disappears completely.
DaneLLL
2
Please check the following post:
https://devtalk.nvidia.com/default/topic/1062786/jetson-nano/jetson-nano-serial-port-data-reading-problem/post/5393006/#5393006
Related topics
| /dev/ttyTHS1 RX working but TX not | 4 | 1796 | December 29, 2019 | |
| Jetson Nano Serial Port data reading problem | 17 | 12010 | October 21, 2020 | |
| Uart TX not working | 17 | 5492 | November 3, 2020 | |
| /dev/ttyTHS2 unable to transmit | 7 | 840 | June 30, 2023 | |
| J41, j44 Serial port not working - jetson nano | 1 | 1972 | June 8, 2020 | |
| Jetson Nano UART (/dev/ttyTHS1) writing is not working | 1 | 795 | December 21, 2021 | |
| Jetson Nano UART TX pins constantly incorrect voltage levels | 8 | 3625 | May 20, 2021 | |
| Sending Serial (RX-TX) data from Jetson Nano to Arduino | 2 | 1837 | May 18, 2020 | |
| Unreliable serial communcation via the UART TX/RX GPIO Pins | 28 | 11689 | July 2, 2021 | |
| Serial.write 1,2,4 or 8 to Aduino with Jetson Nano | 1 | 955 | December 28, 2020 |
