Hello @hoanganhv1svm
Are you sure it worked.? Because the DTB flashing using dd command reflects it changes in the system after a reboot only. Plus You can verify if the intended DTB is flashed by checking the DTB build time after the reboot by command dmesg | grep -i dtb
Also, May I know which L4T Version are you using.?
I am wondering what release you are using? There was similar issue on jetpack4.2.1 but should already be resolved in JP4.3 or JP4.4 EA. Need to find out the old topic.
I’m sure dd work, “reboot” that mean i flash by dd command and “reboot” 1st time, i can see “/proc/device-tree” changed.
If i “reboot” again without dd command, device tree is reverse to origin.
I’m using Jetpack 4.3
