If I understand correctly, there are 2 separate device tree files:
- one in u-boot
- and one for kernel.
Is that correct ?
I see that for linux the device tree is built with make dtbs.
Is it build in u-boot as part of the u-boot build command (make) ?
Thank you,
ranran
Things change depending on release. I have not gone through all of the docs on R28.2, but it looks like there are three device trees (where one tree might or might not be merged with another as boot progresses), plus a copy for some sort of new redundancy feature. If you look at “sudo gdisk -l /dev/mmcblk0” and consider partition labels with “dtb” in their names you will see:
6 60065793 60066816 512.0 KiB 0700 bootloader-dtb
7 60066817 60067840 512.0 KiB 0700 bootloader-dtb_b
13 60086641 60087640 500.0 KiB 0700 bpmp-fw-dtb
14 60087641 60088640 500.0 KiB 0700 bpmp-fw-dtb_b
26 61043009 61044032 512.0 KiB 0700 kernel-dtb
27 61044033 61045056 512.0 KiB 0700 kernel-dtb_b
Each is filled with a signed device tree. The copies seem to be exact matches, so although six partitions are listed there are only three device trees. From a flash log for a dev kit carrier based flash I see:
Writing partition bootloader-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt
Writing partition kernel-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
I’m not positive, but I suspect these (minus the signature which added the “.encrypt” naming) would all be built in a “make dtbs” target for the kernel if the correct config is used (I can’t verify that, it could be wrong). After a make dtbs you might go to the base of the source tree and run this:
tegra186-quill-p3310-1000-c03-00-base*.dtb
tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2*.dtb
ranchu,
I guess you are asking what is the difference of dtb between bootloader and kernel.
Bootloader dtb is loaded and may be modified by cboot and uboot. After that, it is passed to kernel.
