Difference between publish direct message and using nvmsgconv+nvmsgbroker
Hi, I see this file librdkafka/examples/producer.c at master · confluentinc/librdkafka · GitHub allow me publishing information to broker. And I don’t know the difference between this code and using nvmsgconv+nvmsgbroker in your code examples?
The nvmsgconv and nvmsgbroker is made for the gstreamer framework or deepstream. The other is just a library which can be consume in a normal application.
• DeepStream Version
• TensorRT Version
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
nvmsgconv+nvmsgbroker is ready-made code to generate json string and send to broker. please refer to the doc nvmsgconv nvmsgbroker. you may use the custom code to replace nvmsgconv+nvmsgbroker functionality.
