In the Deepstream-app sample, I add a sink “msgconv-msgbroker” into the pipeline. I should have set it rightly. But I cannot get the message in other end, kafka. I wonder if the msgconv lib is Ok, so I print something in the function nvds_msg2p_generate. It does not output anything. So this function does not work. Which function is must be conducted? How can I know what is happening?
ps. I did not receive any error feedback, but many warns about broker like the following: WARN: <broker_queue_overrun:185>: nvmsgbroker queue overrun; Older Message Buffer Dropped; Network bandwidth might be insufficient
If I change the parameter from “msg-broker-conn-str=127.0.0.1;9092;test” to “msg-broker-conn-str=127.0.0.1;9092:test”, a error will be feedback.
The important thing is what function is conducted to transfer the frame metadata to the schema payload, if the function nvds_msg2p_generate is not, in the deepstream-app sample. It is important because it is the last chance to check the message for the broker.
Message conversion called by msg2p_generate_multiple or msg2p_generate based on flag multiplePayloads in nvmsgconv plugin code sources/gst-plugins/gst-nvmsgconv/gstnvmsgconv.c and these two functions will call into generate_deepstream_message_minimal or generate_schema_message based on payload type is NVDS_PAYLOAD_DEEPSTREAM_MINIMAL or NVDS_PAYLOAD_DEEPSTREAM.
This is the log information. It seems that kafka is connected, but kafka consumer does not receive any message, and I do not set any consumer in my app. The function which should work does not work, and the function which should not work does work.
Aug 25 06:48:59 deepstream-app: DSLOG:NVDS_KAFKA_PROTO: kafka partition key field name = sensor.id#012 Aug 25 06:48:59 deepstream-app: DSLOG:NVDS_KAFKA_PROTO: Consumer group id not specified in cfg. Using default group id: test-consumer-group #012 Aug 25 06:48:59 deepstream-app: DSLOG:NVDS_KAFKA_PROTO: Kafka connection successful#012
Please change echo “if ($msg contains ‘DSLOG’) and ($syslogseverity <= 6) then $nvdslogfilepath” >> 11-nvds.conf
to
echo “if ($msg contains ‘DSLOG’) and ($syslogseverity <= 7) then $nvdslogfilepath” >> 11-nvds.conf
in sources/tools/nvds_logger/setup_nvds_logger.sh
get debug level message.
