Using nvmsgconv and nvmsgbroker with the gst-launch-1.0 command line
• Hardware Platform (Jetson / GPU) Jetson AGX Orin
• DeepStream Version 6.1.1
• TensorRT Version
Hi, I would like to use nvmsgbroker with the gst-launch-1.0 command line. I have the broker config working with the deepstream-test4 app, and I can see the payload sent to the redis and the nvds logger. Using the same nvmsgbroker config with gst-launch, the library establishes a connection to the redis server, but it doesn’t send any payload msgs. NVOSD can read the metadata and print the bounding boxes, meaning the metadata is being generated by nvinfer. I tee’ing that to the nvmsgconv and nvmsgbroker elements. When I tried debugging the nvmsgconv source code, I don’t see any msg coming into gst_nvmsgconv_transform_ip
gst-launch-1.0 --gst-debug=2,nvinfer:6 uridecodebin3 uri=sample_720p.h264 !   nvstreammux name=m m.sink_0
 batch-size=1 width=640 height=480 batch-size=1  ! queue ! nvvideoconvert ! queue ! nvinfer config-file-path=config_infer_primary.txt ! tee name=t ! queue ! nvvideoconvert   !  nvdsosd process-mode=GPU_MODE ! queue ! nvegltransform ! nveglglessink sync=true t. ! nvmsgconv config=cfg_msgconv.txt payload-type=1 msg2p-lib=libnvds_msgconv.so ! nvmsgbroker proto-lib= /opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so topic=mystream config=cfg_redis.txt
please refer to this topic:Nvmsgconv - #2
if still can’t work, please check by this:
  1. please add logs in gst_nvmsgconv_start and gst_nvmsgbroker_start to check if start successfully.
  2. to narrow down this issue, please try the pipeline without display, gst-launch-1.0 --gst-debug=2,nvinfer:6 uridecodebin3 uri=sample_720p.h264 ! nvstreammux name=m m.sink_0
    batch-size=1 width=640 height=480 batch-size=1 ! queue ! nvvideoconvert ! queue ! nvinfer config-file-path=config_infer_primary.txt ! nvmsgconv config=cfg_msgconv.txt payload-type=1 msg2p-lib=libnvds_msgconv.so ! nvmsgbroker proto-lib= /opt/nvidia/deepstream/deepstream/lib/libnvds_redis_proto.so topic=mystream config=cfg_redis.txt
I confirmed that gst_nvmsgconv_start and gst_nvmsgbroker_start are both starting successfully. What I noticed that in gst_nvmsgconv_transform_ip , the user_meta_list is also zero length. whereas for the Deepstream-test4 execution, I get that array length >0 in batches.
I also tried running the pipeline without display and tee. Still no event.
I wonder if nvmsconv and nvmsgbroker are supposed to work with nvinfer on the gst-launch-1.0 command line?
I notice that deepstream-test4 the probe is add meta and if I comment it our, the I don’t get any paylood on the nvmsgbroker output.
Do I need to set any property in the nvinfer to generate or attach the meta data? is there anywhere else before transform_ip I can try to trap the meta data?
I was looking at gstnvinfer code, it refers to nvds_add_user_meta_to_obj and nvds_add_user_meta_to_frame functions but I cant find the implementation of that.
please refer to generate_event_msg_meta of osd_sink_pad_buffer_probe in deepstream_test4_app.c, you need to add NvDsEventMsgMeta in user meta.
Was this topic helpful? Nvmsgconv
