Gstreamer pipeline freezes with nvmsgbroker
• Hardware Platform (Jetson / GPU) - DGPU
• DeepStream Version - 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535
Note: Using Nvidia docker container
I am trying to execute below gst pipeline which comprises of nvmsgbroker as well as nvmsgconv.
But the pipeline freezes (with blank screen in the display window).
In my initial level of analysis, I suspect nvmsgbroker might be the cause.
Also, note that Kafka broker is set up and running properly alongside and I am able to validate the connection thro standalone application “deepstream-occupancy-analytics”.
Kindly let me know what am I missing here.
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=1 unique-id=1 ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt batch-size=16 unique-id=2 infer-on-gie-id=1 infer-on-class-ids=0 ! tee name=t1 t1. ! nvmsgconv config=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-occupancy-analytics/config/dstest_occupancy_analytics.txt msg2p-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_msgconv.so ! nvmsgbroker conn-str=“localhost;9092;quickstart-events” proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so sync=FALSE async=FALSE topic=quickstart-events t1. ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! nvvideoconvert ! nvdsosd ! nveglglessink
Best Regards,
Prabakaran R
Could you try running two pipelines separately without using the tee plugin first? One is msgconv+msgbroker, the other is nveglglessink.
When I run the pipeline seperately,
nveglglessink (without msgconv+msgbroker), it works
msgconv+msgbroker (without nveglglessink), execution closes immediately
BTW, I tried and explored different options, and I found that when I introduce ‘queue’ plugin (as like below), then the pipeline is working. Hope the approach is correct
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt batch-size=1 unique-id=1 ! nvtracker ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt batch-size=16 unique-id=2 infer-on-gie-id=1 infer-on-class-ids=0 ! tee name=t1 t1. ! queue ! nvmsgconv config=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-occupancy-analytics/config/dstest_occupancy_analytics.txt msg2p-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_msgconv.so ! nvmsgbroker conn-str=“localhost;9092;quickstart-events” proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so sync=FALSE async=FALSE topic=quickstart-events t1. ! nvmultistreamtiler rows=1 columns=1 width=1280 height=720 ! queue ! nvvideoconvert ! queue ! nvdsosd ! queue ! nveglglessink
The approach is OK. You can refer to our demo code: opt\nvidia\deepstream\deepstream\sources\apps\sample_apps\deepstream-test4\deepstream_test4_app.c. The tee plugin is followed by two queue plugins.
Thanks yuweiw
Appreciate your support
