Differences between ISP pipelines between Jetson AGX Xavier / AGX Orin and NX Orin
Hello all,
I’m using a camera module that outputs bayer data with Jetson AGX Xavier, we’re using a custom isp file (camera_overrides.isp). I want to use this camera module with Jetson AGX Orin and Jetson NX Orin but i don’t what are the differences between the 3 ISP of this boards.
Can you please share some documentations or explain what is the difference between the 3 ISP ?
Also the only source i found from Jetson AGX Xavier ISP is this screenshot but i didn’ found the document of this latter, can you provide it
The ISP tuning material only release to camera partner.
Please contact with partner for IQ tuning.
Hi @ShaneCCC
Thank you for your answer, i’m aware that there is a specific calibration tool that can be used only by nvidia partners to generate custom ISP, but i just want to know if AGX Xavier and AGX Orin have different ISP hardware or it’s the same pipeline ?
Yes, it’s different ISP HW for Xavier and Orin.
@ShaneCCC Can you please give some examples about the main differences according to their tuning parameters ?
Sorry I don’t have idea for it. Usually the tool able detect the chip to generate proper parameters for it.
@ShaneCCC
Can you tell if the Orin NX and the AGX Orin have the same ISP architecture ?
Yes the Orin series is the same ISP architecture but the working clock is different. (performance)
