I’ve been trying to turn off all the main cores and only try working on the 5th low power core.
I followed the short description here:
http://elinux.org/Jetson/Performance
Restricting to low-power core only
Restricting the CPU to the low-power companion core can significantly reduce peak power (if running on a power-limited battery pack, for example). The 5th companion core in Tegra K1 is still a Cortex-A15 core with NEON and 32KB L1 cache and 512KB L2 private cache, but obviously at lower performance than the 4 main cores. To use just the low-power core, run this as root:
echo 0 > /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable
echo LP > /sys/kernel/cluster/active
But I get:
What am I doing wrong here? What’s the work around?
EDIT: Perhaps the commands need to be added to some startup script?
kulve
October 22, 2014, 6:30am
#2
Which one of the echo commands gives you the device busy error?
Last one:
It turns out that the Wiki was missing some info. So I’ve updated the Wiki to show how to check which cluster & cores & frequencies you are currently running at, and how to switch purely to the 5th shadow core:
Thanks Shervin, will give it another go in little while and update you on the results.
