I’m running some timings and power measurements for simulation code on the TX1. Since the board has the low power companion cores I wanted to see how those differed from the main cores and wanted to just run the LP cluster. I want to force just the LP cores but I haven’t figured out how.
I tried modifying the instructions from here:
[url]https://devtalk.nvidia.com/default/topic/894945/jetson-tx1/jetson-tx1/7[/url]
and here:
[url]http://elinux.org/Jetson_TK1[/url]
to force just the low power cores on the TX1. It seems that with the new L4T R24.1 the cluster options have either been moved somewhere else or removed all together.
Is it still possible to force just the low power cores to run?
