Disable cache per variable
Hey there.
I want to disable the caching mechanism for some of the data fields of my structures.
Something like that:
struct Foo {
float4 bar0;
float4 bar1;
float4 bar2;
float4 bar3;
disable_cache float4 bar4;
Is there a way to do that ?
It sounds like you’re asking for the “volatile” qualifier.
[url]http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#volatile-qualifier[/url]
Does that help?
I was afraid that the compiler might turn off all kind of optimizations when using the volatile keyword. I need just the caching off.
What are you trying to achieve? Might memory fence functions be what you are after?
You can switch off L1 memory caching for a variable using inline ptx load/store instructions. To ensure visibility between threads though you should in addition memory fence instructions as stated by tera above.
