Disabling Watchdog for Kernel Debugging
Is there a way to disable watchdog timer/reset on Jetson TX2? I was debugging the kernel module I have made and if I waited too long (ex. examining stack traces, symbols, registers), TX2 resets and this makes it almost impossible to debug my module. Any help is appreciated!
I tried to disable it by running the following command:
echo 1 > /sys/kernel/debug/30c0000.watchdog/disable_dbg_reset
echo 1 > /sys/kernel/debug/30c0000.watchdog/disable_por_reset
But this throws the following error:
-bash: echo: write error: Invalid argument
Try reference to below to implement user space APP for it.
Or disable the kernel config to rebuild the kernel.
  • Can you link to a reference for me to see?
  • Completely disabling it makes the debugger not working…
Have a check below topic.
I already removed CONFIG_WATCHDOG_NOWAYOUT from my kernel config but the device still resets itself if you sit in the debugger for a long duration…
Write the APP to disable the WDT by IOCTL.
