We are currently having an issue accessing the discrete GPU on Drive PX2 Autochauffeur. We can see the stats in tegrastats and query the current frequency.
However, running examples such as nvrm_gpuclk will return an error with a bug report: Bug 200215060 workaround enabled.
Using cudaGetDeviceProperties and cudaGetDeviceCount is also fruitless and only the integrated GPU is reported as available.
Incidentally, we tried updating our PX2 (so maybe that solves the problem) using the SDK manager, but the second step does not load with a loadStage2Error.
Thank you for your help in advance.
Dear soroushbv43y,
Do you see any issue in updating to Drive 1.0 using SDKManager? Could you provide details about the error. Can you check the following thread https://devtalk.nvidia.com/default/topic/1046975/drive-agx/sdkmanager-0-9-9-flash-agx-failed/post/5313645/#5313645 to see if the provided solution worked for you and update us
Thank you for your response. SDKManager fails before step 3. I have attached the error we get in Step 2. This is even before we can enable logging, so we do not know the source of this error.
Here is the screenshot of the error: [url]Dropbox - Step2.png - Simplify your life
Dear soroushbv43y,
This is strange. Please double check System requirements, Proxy settings section in sdkmanager user guide (https://developer.nvidia.com/DRIVE/secure/files/SDKManagerUserGuide.pdf)
Can you delete ~/.nvsdkm folder and download sdkmanager again (https://developer.nvidia.com/DRIVE/secure/files/sdkmanager-0.9.9.2351) and check installing.
Dear soroushbv43y,
Any update here?
Thank you so much for your response.
I have tried the second solution to no avail.
As for system requirements, we were using Linux Mint 19.1 based on Ubuntu 18.04 LTS. I have tried SDKManager on virtual machines (without the USB connection) with the same result. I have tried everything short of installing Ubuntu 16.04 on a physical machine. I will try that and get back to you. Again to reiterate, the issue is in Step 02 while loading the license agreement, etc.
Going back to the original question, do you think that updating to the latest Drive OS would solve our issue with dGPU?
Dear soroushbv43y,
If the issue is related SW, it can be resolved by re-flashing the board. If the issue with HW, you will still notice this issue, in that case get back to us again.
Thank you so much for your help so far. We dedicated a computer just for updating Drive PX2 with Ubuntu 16.04 and we were able to pass step 2 with no problem. However, in step 3, the process is stuck again with the following errors:
17:04:00 ERROR : OSS and NV packages : download error: checksum is wrong
17:04:04 ERROR : DRIVE Foundation OSS Packages : download error: checksum is wrong
17:05:29 ERROR : OSS and NV packages : download error: checksum is wrong
17:05:53 ERROR : DRIVE Foundation OSS Packages : download error: checksum is wrong
17:07:10 ERROR : DRIVE Foundation OSS Packages : download error: checksum is wrong
17:07:10 ERROR : DRIVE Foundation OSS Packages : download ‘DRIVE Foundation OSS Packages’ failure
17:07:27 ERROR : OSS and NV packages : download error: checksum is wrong
17:10:24 ERROR : CUDA on Target : download error: checksum is wrong
17:11:04 ERROR : OSS and NV packages : download error: checksum is wrong
17:11:04 ERROR : OSS and NV packages : download ‘OSS and NV packages’ failure
17:11:20 ERROR : DRIVE Foundation OSS Packages : install ‘DRIVE Foundation OSS Packages’ failure, no file is available to install
17:12:02 ERROR : TensorRT (with cuDNN 7.1) on Target : download error: checksum is wrong
17:12:41 ERROR : OSS and NV packages : download error: checksum is wrong
17:12:49 ERROR : CUDA on Target : download error: checksum is wrong
17:16:03 ERROR : CUDA on Host : download error: checksum is wrong
17:17:57 ERROR : OSS and NV packages : download error: checksum is wrong
17:18:18 ERROR : TensorRT (with cuDNN 7.1) on Host : download error: checksum is wrong
17:19:41 ERROR : CUDA on Host : download error: checksum is wrong
17:21:19 ERROR : TensorRT (with cuDNN 7.1) on Host : download error: checksum is wrong
17:36:40 ERROR : TensorRT (with cuDNN 7.1) on Host : download error: https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/drive-t186ref-linux-5.0.10.3-12606092-host_native_cross-tensorrt--4.0.0.8.run failed with Error: Download did not complete successfully.
17:36:41 ERROR : TensorRT (with cuDNN 7.1) on Host : download ‘TensorRT (with cuDNN 7.1) on Host’ failure
17:36:41 ERROR : TensorRT (with cuDNN 7.1) on Host : download error: checksum is wrong
17:40:51 ERROR : DriveWorks on Host : download error: checksum is wrong
17:41:07 ERROR : Tegra Graphics Debugger : Uncompressing NVIDIA Tegra Graphics Debugger 0%
17:41:07 ERROR : Tegra Graphics Debugger : 1%
17:41:07 ERROR : Tegra Graphics Debugger : 2%
17:41:07 ERROR : Tegra Graphics Debugger : 3%
17:41:09 ERROR : Tegra Graphics Debugger :
17:41:09 ERROR : Tegra Graphics Debugger : 4%
17:41:09 ERROR : Tegra Graphics Debugger : 5%
17:41:09 ERROR : Tegra Graphics Debugger : 6%
17:41:09 ERROR : Tegra Graphics Debugger : 8%
17:41:09 ERROR : Tegra Graphics Debugger : 9%
17:41:09 ERROR : Tegra Graphics Debugger : 10%
17:41:09 ERROR : Tegra Graphics Debugger : 11%
17:41:09 ERROR : Tegra Graphics Debugger : 12%
17:41:09 ERROR : Tegra Graphics Debugger : 13%
17:41:09 ERROR : Tegra Graphics Debugger : 14%
17:41:09 ERROR : Tegra Graphics Debugger : 16%
17:41:09 ERROR : Tegra Graphics Debugger : 17%
17:41:10 ERROR : Tegra Graphics Debugger : 18%
17:41:10 ERROR : Tegra Graphics Debugger : 19%
17:41:10 ERROR : Tegra Graphics Debugger : 20%
17:41:10 ERROR : Tegra Graphics Debugger : 21%
17:41:10 ERROR : Tegra Graphics Debugger : 23%
17:41:10 ERROR : Tegra Graphics Debugger : 24%
17:41:10 ERROR : Tegra Graphics Debugger : 25%
17:41:10 ERROR : Tegra Graphics Debugger : 26%
17:41:10 ERROR : Tegra Graphics Debugger : 27%
17:41:11 ERROR : Tegra Graphics Debugger : 28%
17:41:11 ERROR : Tegra Graphics Debugger : 29%
17:41:11 ERROR : Tegra Graphics Debugger : 31%
17:41:11 ERROR : Tegra Graphics Debugger : 32%
17:41:11 ERROR : Tegra Graphics Debugger : 33%
17:41:12 ERROR : Tegra Graphics Debugger : 34%
17:41:12 ERROR : Tegra Graphics Debugger : 35%
17:41:12 ERROR : Tegra Graphics Debugger : 36%
17:41:12 ERROR : Tegra Graphics Debugger : 37%
17:41:13 ERROR : Tegra Graphics Debugger :
17:41:13 ERROR : Tegra Graphics Debugger : 39%
17:41:13 ERROR : Tegra Graphics Debugger : 40%
17:41:14 ERROR : Tegra Graphics Debugger :
17:41:14 ERROR : Tegra Graphics Debugger : 41%
17:41:14 ERROR : Tegra Graphics Debugger : 42%
17:41:14 ERROR : Tegra Graphics Debugger : 43%
17:41:14 ERROR : Tegra Graphics Debugger : 44%
17:41:15 ERROR : Tegra Graphics Debugger :
17:41:15 ERROR : Tegra Graphics Debugger : 46%
17:41:15 ERROR : Tegra Graphics Debugger : 47%
17:41:15 ERROR : Tegra Graphics Debugger : 48%
17:41:15 ERROR : Tegra Graphics Debugger : 49%
17:41:16 ERROR : Tegra Graphics Debugger :
17:41:16 ERROR : Tegra Graphics Debugger : 50%
17:41:16 ERROR : Tegra Graphics Debugger : 51%
17:41:16 ERROR : Tegra Graphics Debugger : 52%
17:41:16 ERROR : Tegra Graphics Debugger : 54%
17:41:16 ERROR : Tegra Graphics Debugger : 55%
17:41:16 ERROR : Tegra Graphics Debugger : 56%
17:41:17 ERROR : Tegra Graphics Debugger : 57%
17:41:17 ERROR : Tegra Graphics Debugger : 58%
17:41:17 ERROR : Tegra Graphics Debugger : 59%
17:41:17 ERROR : Tegra Graphics Debugger : 60%
17:41:17 ERROR : Tegra Graphics Debugger : 62%
17:41:17 ERROR : Tegra Graphics Debugger : 63%
17:41:18 ERROR : Tegra Graphics Debugger : 64%
17:41:18 ERROR : Tegra Graphics Debugger : 65%
17:41:19 ERROR : Tegra Graphics Debugger : 66%
17:41:19 ERROR : Tegra Graphics Debugger : 67%
17:41:20 ERROR : Tegra Graphics Debugger :
17:41:20 ERROR : Tegra Graphics Debugger : 69%
17:41:20 ERROR : Tegra Graphics Debugger : 70%
17:41:20 ERROR : Tegra Graphics Debugger : 71%
17:41:21 ERROR : Tegra Graphics Debugger :
17:41:21 ERROR : Tegra Graphics Debugger : 72%
17:41:21 ERROR : Tegra Graphics Debugger : 73%
17:41:21 ERROR : Tegra Graphics Debugger : 74%
17:41:21 ERROR : Tegra Graphics Debugger : 75%
17:41:21 ERROR : Tegra Graphics Debugger : 77%
17:41:22 ERROR : Tegra Graphics Debugger :
17:41:22 ERROR : Tegra Graphics Debugger : 78%
17:41:22 ERROR : Tegra Graphics Debugger : 79%
17:41:22 ERROR : Tegra Graphics Debugger : 80%
17:41:22 ERROR : Tegra Graphics Debugger : 81%
17:41:22 ERROR : Tegra Graphics Debugger : 82%
17:41:23 ERROR : Tegra Graphics Debugger :
17:41:23 ERROR : Tegra Graphics Debugger : 84%
17:41:25 ERROR : Tegra Graphics Debugger : 85%
17:41:25 ERROR : Tegra Graphics Debugger : 86%
17:41:25 ERROR : Tegra Graphics Debugger : 87%
17:41:25 ERROR : Tegra Graphics Debugger : 88%
17:41:25 ERROR : Tegra Graphics Debugger : 89%
17:41:26 ERROR : Tegra Graphics Debugger :
17:41:26 ERROR : Tegra Graphics Debugger : 90%
17:41:26 ERROR : Tegra Graphics Debugger : 92%
17:41:28 ERROR : Tegra Graphics Debugger : 93%
17:41:30 ERROR : Tegra Graphics Debugger : 94%
17:41:31 ERROR : Tegra Graphics Debugger :
17:41:31 ERROR : Tegra Graphics Debugger : 95%
17:41:32 ERROR : Tegra Graphics Debugger :
17:41:32 ERROR : Tegra Graphics Debugger : 96%
17:41:34 ERROR : Tegra Graphics Debugger :
17:41:34 ERROR : Tegra Graphics Debugger : 97%
17:41:35 ERROR : Tegra Graphics Debugger :
17:41:35 ERROR : Tegra Graphics Debugger : 98%
17:41:37 ERROR : Tegra Graphics Debugger : 100%
17:42:07 ERROR : DriveWorks Cross Compilation : download error: checksum is wrong
17:42:48 ERROR : DriveWorks Cross Compilation : download error: checksum is wrong
17:43:22 ERROR : DriveWorks on Host : download error: checksum is wrong
17:45:14 ERROR : DriveWorks on Host : download error: checksum is wrong
17:45:14 ERROR : DriveWorks on Host : download ‘DriveWorks on Host’ failure
The installer indicates that the download is completed successfully but the details tab reflects these errors. The installation freezes at 15% (I have tried leaving it for a full day). I would appreciate your help regarding this issue.
I have managed to bypass the previous problem. However, I now consistently get the following errors when I try to flash Tegra A, or Tegra A+B, or Tegra B. I would appreciate your help on this matter.
16:10:14 INFO : Flash Tegra A :
16:10:14 INFO : Flash Tegra A : Target will be flashed with rootfs in eMMC
16:10:14 INFO : Flash Tegra A : Aurix Port = /dev/ttyUSB1
16:10:14 ERROR : Flash Tegra A : stty: /dev/ttyUSB1
16:10:14 ERROR : Flash Tegra A : : Permission denied
16:10:15 INFO : Flash Tegra A : Successfully acquired lock over /var/lock/LCK…bootburn_seq
16:10:15 INFO : Flash Tegra A : Successfully acquired lock over /var/lock/LCK…ttyUSB1
16:10:15 INFO : Flash Tegra A : Disabling SIGINT temporarily
16:10:15 ERROR : Flash Tegra A : Setting Tegra-A on hold… /dev/ttyUSB1:
16:10:16 INFO : Flash Tegra A : cat: /dev/ttyUSB1: Resource temporarily unavailable
16:10:27 INFO : Flash Tegra A : Could not execute command “tegrareset a h” on aurix. Log follows,
16:10:27 INFO : Flash Tegra A : ------------ Stack Trace ------------
16:10:27 INFO : Flash Tegra A : stack frame 0 - 384 AbnormalTermination /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_lib.sh
16:10:27 INFO : Flash Tegra A : stack frame 1 - 284 ExecuteAurixCommand /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_target.sh
16:10:27 INFO : Flash Tegra A : stack frame 2 - 134 GetTegrasAssocWithAurix /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_target.sh
16:10:27 INFO : Flash Tegra A : stack frame 3 - 360 CheckRecoveryTargets /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_target.sh
16:10:27 INFO : Flash Tegra A : stack frame 4 - 457 SequencerSetupTarget /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_sequencer.sh
16:10:27 INFO : Flash Tegra A : stack frame 5 - 475 SeqFlashTarget /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_sequencer.sh
16:10:27 INFO : Flash Tegra A : stack frame 6 - 518 source /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_sequencer.sh
16:10:27 INFO : Flash Tegra A : stack frame 7 - 318 source /home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/bootburn_core.sh
16:10:27 INFO : Flash Tegra A : stack frame 8 - 44 main tools/host/flashtools/bootburn/bootburn.sh
16:10:27 INFO : Flash Tegra A : -------------------------------------
16:10:27 INFO : Flash Tegra A : error-aurix-command
16:10:27 ERROR : Flash Tegra A : stty: /dev/ttyUSB1: unable to perform all requested operations
16:10:27 INFO : Flash Tegra A : Unable to restore Aurix Console Params
16:10:27 INFO : Flash Tegra A : Bootburn operation unsuccessful
16:10:27 INFO : Flash Tegra A : The following tips can help troubleshoot bootburn failures. These are based on
16:10:27 INFO : Flash Tegra A : known issues related to setup or missing configuration. If it doesn’t help
16:10:27 INFO : Flash Tegra A : resolve the issue, contact module owners with a copy of the full log.
16:10:27 INFO : Flash Tegra A : error= error-aurix-command
16:10:27 INFO : Flash Tegra A : * The Aurix console did not regognize the command given to it. Please review
16:10:27 INFO : Flash Tegra A : the logs and make sure that the command that you are sending is valid
16:10:27 INFO : Flash Tegra A : bootburn flashing failed! error code = 37
16:10:27 INFO : Flash Tegra A : exit status 37
16:10:27 ERROR : Flash Tegra A : Failed to flash device: please check /home/soroosh/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS/flash_2379_Tegra_A.log for more details.
16:10:27 INFO : Flash Tegra A : InstallUtil returns: exit status 1
16:10:27 ERROR : Flash Tegra A : command terminated with error
16:10:27 ERROR : Flash Tegra A : install ‘Flash Tegra A’ failure, command < cd ‘/home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ ; /opt/nvidia/sdkmanager/resources/app.asar.unpacked/output/installUtils/adapter -a=‘install’ -b=‘NV_DRIVE_LINUX_BUNDLE’ -c=‘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’ -i=‘NV_FLASH_TEGRA_A_COMP’ -v=‘5.0.10.3’ -l=‘/home/soroosh/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS’ -L=‘/home/soroosh/.nvsdkm/logs/DRIVE/Linux/5.0.10.3/OS’ -p=‘25386’ -u=‘/opt/nvidia/sdkmanager/resources/app.asar.unpacked/output/installUtils/NV_DRIVE_LINUX_BUNDLE/common/_installer/InstallUtil’ -t=‘PX2_AUTOCHAUFFEUR’ -x=‘SDK’ -e=‘/home/soroosh/Downloads/nvidia/sdkm_downloads’ > terminated with error
16:10:27 INFO : Flash Tegra B : install ‘Flash Tegra B’ Skipped
