I encountered the following error when flashing the Xavier AGX board w/ new SW 8.0 using sdkmanager 0.9.9 beta.
The following are section of the log showing the reported error. Full log is attached
Could you help ?
2019-02-01 10:27:37.601 - info: ./bootburn.sh -b e3550b03-t194a -B qspi -x /dev/ttyUSB3
2019-02-01 10:27:38.886 - info: Execute Xavier Script
2019-02-01 10:27:38.886 - info: Successfully acquired lock over /var/lock/LCK..bootburn
2019-02-01 10:27:38.886 - info: Successfully acquired lock over /var/lock/LCK..ttyUSB3
2019-02-01 10:27:38.886 - info: Read skuinfo from InfoRom...
[b]2019-02-01 10:27:40.745 - error: /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh: line 774: array: bad array subscript
2019-02-01 10:27:41.693 - error: /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh: line 774: array: bad array subscript[/b]
2019-02-01 10:27:41.693 - info: Disabling SIGINT <Ctrl+C> temporarily
2019-02-01 10:27:44.104 - info: Setting Tegra-A on hold... Done
2019-02-01 10:27:46.795 - info: Setting Tegra-B on hold... Done
2019-02-01 10:27:52.343 - info: Setting Tegra-A in recovery... Done
2019-02-01 10:27:58.092 - info: Setting Tegra-B in recovery... Done
2019-02-01 10:27:58.093 - info: Enabling SIGINT <Ctrl+C>
2019-02-01 10:28:03.257 - info:
2019-02-01 10:28:03.258 - info: ------------ Stack Trace ------------
2019-02-01 10:28:03.258 - info: stack frame 0 - 287 AbnormalTermination /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
2019-02-01 10:28:04.148 - info: stack frame 1 - 1084 GetTargetECID /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
2019-02-01 10:28:04.148 - info: stack frame 2 - 340 source /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_active.sh
2019-02-01 10:28:04.148 - info: stack frame 3 - 1014 main /mnt/home2/davyhuang/work/nvidia/nvidia_sdk/DRIVE/Linux/5.0.13.2/SW/DriveSDK/drive-t186ref-foundation/tools/host/flashtools/bootburn/../bootburn_t19x//bootburn.sh
SDKM_logs_DRIVE_Software_8.0_Linux_for_DRIVE_AGX_Developer_Kit_02012019_1021.zip (530 KB)
