Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
So this morning when I tried to turn on xavier board it seemed stuck, fans were low speed and no display. Looking at the aurix console I saw this error
The board has been powered off.
Low Voltage detected on KL30_Power
Forced Power On after 30sec timeout
System_PowerOn: Reading PG status: Timeout Error!
X1_XA_VDD_SOC_XA_VDD_DDR2_XA_VG
IOHWABS_PWRUP_SEQUENCE_ERROR : PowerOn sequence encountered errors...
<repeats forever>
I then powered down and rechecked all connections, and after restart it seemed aurix was OK but Tegra A failed to boot
[0000.022] I> MB1 (prd-version: s_1.6.0.0-t194-41334769-fac5b753)
[0000.028] I> Boot-mode: Coldboot
[0000.031] I> Chip revision : A02
[0000.034] I> Bootrom patch version : 15 (correctly patched)
[0000.039] I> ATE fuse revision : 0x200
[0000.042] I> Ram repair fuse : 0x0
[0000.045] I> Ram Code : 0x1
[0000.048] I> rst_source : 0x0
[0000.051] I> rst_level : 0x0
[0000.054] I> Boot-device: QSPI
[0000.057] I> Qspi flash params source = brbct
[0000.061] I> Qspi using bpmp-dma
[0000.064] I> Qspi clock source : pllp
[0000.067] W> DEVICE_PROD: device prod is not initialized.
[0000.072] I> QSPI Flash Size = 64 MB
[0000.076] I> Qspi initialized successfully
[0000.079] I> Active Boot chain : 0
[0000.083] I> Boot-device: QSPI
[0000.085] I> Qspi flash params source = brbct
[0000.091] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.097] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.105] I> Temperature = 21000
[0000.108] W> Skipping boost for clk: AON_CPU_NIC
[0000.112] W> Skipping boost for clk: CAN1
[0000.116] W> Skipping boost for clk: CAN2
[0000.120] I> Boot-device: QSPI
[0000.123] I> Qspi flash params source = mb1bct
[0000.127] I> Qspi using bpmp-dma
[0000.130] I> Qspi clock source : pllc_out0
[0000.133] W> DEVICE_PROD: device prod is not initialized.
[0000.138] I> Qspi reinitialized
[0000.144] I> Qspi flash params source = mb1bct
[0000.149] I> ECC region[0]: Start:0x0, End:0x0
[0000.153] I> ECC region[1]: Start:0x0, End:0x0
[0000.157] I> ECC region[2]: Start:0x0, End:0x0
[0000.161] I> ECC region[3]: Start:0x0, End:0x0
[0000.165] I> ECC region[4]: Start:0x0, End:0x0
[0000.169] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.175] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.179] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.184] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.188] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.194] W> DEVICE_PROD: device prod is not initialized.
[0000.200] W> DEVICE_PROD: device prod is not initialized.
[0000.206] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config tabl.
[0000.213] E> FAILED: MEMIO rail config
[0000.225] I> scrub mode: full dram
[0000.230] I> Boot-device: QSPI
[0000.233] I> Qspi flash params source = mb1bct
[0000.290] E> MB1_PLATFORM_CONFIG: Bootrom mmio i2c table is empty in MB1 BCT.
[0000.299] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config tabl.
[0001.514] E> WP1.5 ACK pending
[0001.516] E> Error: 0
[0001.519] E> Task 79 failed (err: 0x32320006)
[0001.523] E> Top caller module: CPUINIT, error module: CPUINIT, reason: 0x06, 0
[0001.531] I> MB1(s_1.6.0.0-t194-41334769-fac5b753) BIT boot status dump :
01111111111111111111101111111111111111111110111111111011110011111111100101111010
[0001.560] I> Reset to recovery mode
Tegra B booted OK though. I then tried to reflash board with fresh Drive 10.0 software but it encountered flash error during install. nvsdkm.tar.xz (1.8 MB)
Note, this is same board that had issues before,
