Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.1.7402
other
Host Machine Version
native Ubuntu 18.04
other
Hi, I can not flash Drive AGX Xavier dev kit. It’s failed to exec the command “pdkinstaller”:
11:41:54 ERROR: Flash Xavier A+B in parallel: [error]: : [exec_command]: /bin/bash -c cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /media/hunglx/DATA_500GB/Downloads/t12/target_image/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable; [error]: [12799] Failed to execute script pdkinstaller
Please help check the log SDKM_logs_DRIVE_Software_10.0_(rev.2)_Linux_for_DRIVE_AGX_Developer_Kit_2021-03-13_10-45-50.zip (2.5 MB)
Dear @v.hunglx2 ,
Could you please confirm if the requirements in Getting Started with DRIVE Software :: NVIDIA DRIVE AGX System Installation and Setup is followed. I notice some flashing issues with fuseblk partion type(run df -Th on host to know partion type). If so, please check with ext4 partition.
Hi @SivaRamaKrishnaNV ,
i have the same setup with the same problem here.
My host system outputs following with: df -Th
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 7,8G 0 7,8G 0% /dev
tmpfs tmpfs 1,6G 1,9M 1,6G 1% /run
/dev/sda2 ext4 234G 112G 111G 51% /
tmpfs tmpfs 7,8G 763M 7,1G 10% /dev/shm
tmpfs tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs tmpfs 7,8G 0 7,8G 0% /sys/fs/cgroup
/dev/loop0 squashfs 1,0M 1,0M 0 100% /snap/gnome-logs/100
/dev/loop1 squashfs 2,3M 2,3M 0 100% /snap/gnome-system-monitor/148
/dev/loop2 squashfs 384K 384K 0 100% /snap/gnome-characters/550
/dev/loop3 squashfs 256M 256M 0 100% /snap/gnome-3-34-1804/36
/dev/loop4 squashfs 30M 30M 0 100% /snap/snapd/8542
/dev/loop6 squashfs 2,5M 2,5M 0 100% /snap/gnome-calculator/748
/dev/loop5 squashfs 63M 63M 0 100% /snap/gtk-common-themes/1506
/dev/loop7 squashfs 56M 56M 0 100% /snap/core18/1885
/dev/sda1 vfat 511M 6,1M 505M 2% /boot/efi
tmpfs tmpfs 1,6G 44K 1,6G 1% /run/user/1000
I found the exact logs where the flash process stops:
~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump
TegraALog_dpUDptfeFH.txt (19.1 KB) TegraBLog_ynUvzYtjY1.txt (21.5 KB)
command options used = -b e3550b03-t194 -B qspi -x /dev/ttyUSB3 --updtcfga gos1-fs:dirname:/home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/targetfs_a --updtcfgb gos1-fs:dirname:/home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux/targetfs_b -w
------------ Stack Trace ------------
stack frame 0 - 329 AbnormalTermination /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
stack frame 1 - 48 CheckUSBServiceInit /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_adb.sh
stack frame 2 - 2942 FlashImages /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
stack frame 3 - 404 source /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_active.sh
stack frame 4 - 1270 main /home/dspace/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh
Tool OutPut:
Bus 003 Device 018: ID 0955:7100 NVidia Corp. Tegra Device
Tool OutPut to stderr:
error-adb-timeout
@v.hunglx2 maybe you can crosscheck if your fault is the same. Else I will open an seperate thread for my problem.
Dear @mspilker ,
it seems your issue is different. It seems you already filed similar topic at Error 5 during flashing . Could you follow on the same thread?
Dear @SivaRamaKrishnaNV ,
thanks for your reply.
It was the same problem as last time:
Please run below command with the attached zip file right before flashing your system and see if it can fix the issue.
$ unzip -B 5.1.6.1_dtb_files_with_USB_fix.zip -d ~/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/flash/t18x/rcmkernel
5.1.6.1_dtb_files_with_USB_fix.zip (134.1 KB)
Just the errorcode was missing from last time
Flashing process exited with error 5
which mislead me to this thread.
Dear @mspilker ,
So, is the issue fixed?if not please file new topic.
Hello @SivaRamaKrishnaNV ,
yes, the zip file from the other thread solved my problem - excuse me for not expressing myself precisely
Dear @yafei.meng ,
Could you please file a new topic?
Dear @v.hunglx2 ,
Could you provide any update on the issue?
because when i launch the sdkmanager, got some APT repo connection issue.
then i give up to flash the board.
Hi, the issue was caused by not having enough storage space. Now I can flash Drive AGX normally.
