Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Hi, I am trying to flash Drive AGX and it gets failed immediately. Can you please help me with that?
I tried flashing using docker and it got failed as well, I attached the log.
I noticed the following messages in your logs. Can you please provide information on any setup differences compared to your previous successful flashing? Have you ensured that the USB cable is correctly connected? Also, have you tried power cycling both the host system and the target system?
PDK Installer failed with status 144
FlashTegraPDKInstaller failed, error 144!
Could you please provide additional details regarding the reason for reflashing the devkit? What specific issue or observation prompted the need for reflashing? Also, please provide the versions of Xavier and Aurix before attempting the flashing process.
The display was gone and was trying to bring back the display so I decided to reflash.
And previous, I was able to flash using docker and remove the nvsdkm/uninstall and install again using sdkmanager but this time got failed both approaches.
