Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
With a new AGX machine the Aurix version is 5.1.6
And I am trying to flash Drive 5.2.0 , but flash is not successfull
Error code NvError_ResourceError 15 or
NvError_NvImagegen 53 is seen
Is there compatibilty issue?
kayccc
August 19, 2021, 6:19am
3
Are you using SDK Manager? If not, please download the latest SDK Manager via https://developer.nvidia.com/nvsdk-manager and try with it.
Or please help to provide the logs in ~/.nvsdkm/ directory.
sdkm-2021-08-19-13-53-05.zip (23.4 KB)
Yes sdk manager is 1.6, latest I believe.
Aurix Version
shell> version
Info: Executing cmd: version, argc: 0, args:
SW Version: DRIVE-V5.1.6-E3550-EB-Aurix-With3LSS-ForHyperion-StepA-3.05.04
Compilation date: Jun 25 2019, 14:25:36
Command Executed
Log are also attached
VickNV
August 19, 2021, 2:30pm
7
Hi @mohan.kamatam ,
Do you have enough disk space on your host system (from System Requirements )?
If you don’t think it’s caused by no enough disk space.
Please help to compress ~/.nvsdkm directory and upload it for our analysis.
There is enough space.
But I always get error which says.
000.sdhci] Flashing for Partition A_1_gos1-gp1
13:59:13.338 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: [bootburnTegra-A]: [executeShellCommand(154)] : shell command – /home/xxxxx/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/flash/adb -s 2P3U4N40G00000A050K0 push A_1GPT_pri00_03.bin /tmp failed
13:59:13.338 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: [bootburnTegra-A]: [executeShellCommand(156)] : {‘cmd’: [‘/home/xxxxx/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/flash/adb’, ‘-s’, ‘2P3U4N40G00000A050K0’, ‘push’, ‘A_1GPT_pri00_03.bin’, ‘/tmp’], ‘output’: “adb: error: failed to read all of ‘A_1GPT_pri00_03.bin’: Operation not permitted\n”, ‘returncode’: 1}
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: [bootburnTegra-A]: [executeShellCommand(158)] : adb: error: failed to read all of ‘A_1GPT_pri00_03.bin’: Operation not permitted
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: [bootburnTegra-A]: [executeShellCommand(161)] : 1
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: command line used was:
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: [‘./bootburn.py’, ‘-b’, ‘e3550b03-t194a’, ‘-B’, ‘qspi’, ‘-x’, ‘/dev/ttyUSB3’]
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: Adb push failed – /home/xxxxx/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/flash/adb -s 2P3U4N40G00000A050K0 push A_1GPT_pri00_03.bin /tmp000.sdhci] Flashing for Partition A_1_gos1-gp1
13:59:13.339 - info: NV_DRIVE_FLASH_DDPX_X1_COMP@DDPX: Adb push failed – /home/xxxxxx/nvidia/nvidia_sdk/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/flash/adb -s 2P3U4N40G00000A050K0 push A_1GPT_pri00_03.bin /tmp
.nvsdkm.7z (265.4 KB)
VickNV
August 26, 2021, 2:33pm
9
Did you select flash both Xavier A and B? If not, could you try Flash Xavier A+B in parallel?
BTW, DRIVE OS 5.2.6 is available. You may try to install it.
I have tried all combination with 5.2.0/3 .
Any reason none of this can help. As I have to also try with other ADX HW which I have not tried flashing.
Also 5.2.6 is not available via sdk manager online partner tab.
VickNV
August 26, 2021, 3:37pm
11
Please try with “NVIDIA DEVELOPER” as below.
This forum is to support releases installed via it.
VickNV
August 26, 2021, 7:38pm
12
Please also make sure ttyUSB devices aren’t occupied by other processes.
So you can try after rebooting your host system.
