Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.4.0.7363
other
Host Machine Version
native Ubuntu 18.04
other
Issue
We have a Pegasus unit that was working fine for a few weeks but recently the Xaviers have stopped responding. We could not communicate via ethernet, serial, or through external monitors. The Aurix was also not responsive over serial
I tried re-flashing the unit using the Nvidia SDK. The flash reached 99% but did not progress further. Eventually a dialog popped up saying Installation of 'Flash Xavier A+B in parallel' is taking longer than expected. Do you want to continue installing this package?
. After selecting continue
and waiting a while longer, I exited the process. Logs here: 010_flashing.log (104.6 KB)
After flashing, I was able to connect to the Aurix and saw a stream of the following error:
ERROR: PSM_ModMgr: MODMGR_ERROR
I have also attached a log of Aurix command responses to help diagnose the issue: 010_drive_post_flash_aurix.txt (6.4 KB)
Can you elucidate what may be wrong with the unit and how we may be able to repair it?
Thank you,
Osman
