Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Hi Vick! The aurix boot log is attached. I will try re-flashing it now with DriveOS 5.2 (same as what was running on it prior to the current boot error)
Then I flashed the Aurix with updated firmware and ran the showvoltages command:
Shell>showvoltages
INPUTS:
KL30_VBAT = 12.221 V
KL30_POWER = 12.199 V
KL15_POWER = 12.214 V
AURIX:
AURIX_1V3 = 1.255 V
AURIX_3V3 = 3.327 V
AURIX_5V = 4.996 V
CAN1_5V = 5.022 V
CAN2_5V = 5.007 V
FR_5V = 5.011 V
HRNS_GPI = 0.402 V
SYSTEM:
VBAT_SYS = 0.073 V
VBATSYS_ISENSE = 0.010 A
SYS_5V = 0.055 V
SYS_0V85 = 0.000 V
SYS_0V92_1 = 0.000 V
SYS_0V92_2 = 0.003 V
SYS_1V0 = 0.001 V
SYS_1V1_2 = 0.001 V
SYS_1V2 = 0.001 V
SYS_1V5_2 = 0.001 V
SYS_1V8_1 = 0.388 V
SYS_1V8_2 = 0.573 V
SYS_2V1 = 0.001 V
SYS_2V5 = 0.001 V
SYS_3V3_1 = 0.537 V
SYS_3V3_2 = 0.311 V
CE_PREREG = 0.005 V
Tegra A:
VBAT_TEG = 12.214 V
VBATTEG_ISENSE = 1.114 A
XA_PREREG = 12.125 V
XA_5V = 5.096 V
XA_5V_SW = 5.065 V
XA_VDD_1V0 = 1.003 V
XA_VDD_1V8_AO = 1.805 V
XA_VDD_1V8_HS = 1.809 V
XA_VDD_1V8_LS = 1.807 V
XA_VDD_CPU = 1.106 V
XA_VDD_CV = 1.079 V
XA_VDD_DDR2 = 1.112 V
XA_VDD_DDRQ = 0.606 V
XA_VDD_DDR_1V1 = 1.161 V
XA_VDD_GPU = 1.098 V
XA_VDD_SOC = 0.021 V
X1_DGPU_THERM_ALERT_N = 1.808 V
VBAT_SXMA = 0.014 V
VBATSXMA_ISENSE = 0.020 A
SXMA_PREREG = 0.005 V
Tegra B:
XB_PREREG = 12.095 V
XB_5V = 5.100 V
XB_5V_SW = 5.102 V
XB_VDD_1V0 = 1.002 V
XB_VDD_1V8_AO = 1.803 V
XB_VDD_1V8_HS = 1.804 V
XB_VDD_1V8_LS = 1.813 V
XB_VDD_CPU = 0.001 V
XB_VDD_CV = 0.001 V
XB_VDD_DDR2 = 1.112 V
XB_VDD_DDRQ = 0.608 V
XB_VDD_DDR_1V1 = 1.158 V
XB_VDD_GPU = 0.001 V
XB_VDD_SOC = 0.854 V
X2_DGPU_THERM_ALERT_N = 1.814 V
VBAT_SXMB = 0.014 V
VBATSXMB_ISENSE = 0.020 A
SXMB_PREREG = 0.011 V
CVM:
P1_PREREG = 12.077 V
P1_5V = 5.135 V
Also attaching a log here where I run poweron and aurixreset before showvoltages updated_aurix_ev_log.txt (4.5 KB)
The unit was being powered directly from the power supply included in the Dev kit. This was plugged into an inverter on the vehicle. Inverter specs: 230VAC pure sine inverter, 3000W continuous, 6000W max.
