Error while booting
recently another problem appeared. When I try to boot up the AGX the fans doesn’t start and it seems as both tegras won’t boot up.
Aurix reply as follow:
“System_PowerOn: Reading PG status: Timeout Error!”
“X2_XB_VDD_SOC_XB_VDD_DDR2_XB_VDD_DDRQ_PG”
Please find my log below:
version
Info: Executing cmd: version, argc: 0, args:
SW Version: DRIVE-V5.0.13-E3550-EB-Aurix-ForHyperion-3.01.05
Compilation date: Nov 12 2018, 12:50:16
Command Executed
shell> status
Info: Executing cmd: status, argc: 0, args:
Alive       : 00:00:00
CPU load     Core  : 2  %
CPU load max Core  : 100%
CPU load     Core 1: 0  %
CPU load max Core 1: 0 0%
CPU load     Core 2: 0  %
CPU load max Core 2: 0 0%
CPU load     Core 3: 0  %
CPU load max Core 3: 0 0%
CPU load     Core 4: 0  %
CPU load max Core 4: 0 0%
CPU load     Core 5: 0  %
CPU load max Core 5: 0 0%
Hardware information:
SystemUpInit-Time[ms]: 79
IP-address (Tegra-A): 10 .42 .0  .28
IP-address (Tegra-B): 10 .42 .0  .29
IP-address   (AURIX): 10 .42 .0  .146
MAC-address (Tegra-A): 0x000000044BAF781D
MAC-address (Tegra-B): 0x000000044BAF781E
MAC-address   (AURIX): 0x000000044BAF781F
RAM Usage: 1073792704 bytes
Command Executed
shell> poweron
Info: Executing cmd: poweron, argc: 0, args:
Command Executed
shell> tegrarecovery x1 on
Info: Executing cmd: tegrarecovery, argc: 2, args: x1 on
Command Executed
shell> tegrarecovery x2 on
Info: Executing cmd: tegrarecovery, argc: 2, args: x2 on
Command Executed
shell> tegrarestart x1
Info: Executing cmd: tegrarestart, argc: 1, args: x1
Error: Unknown command
Invalid Command
shell> tegrarestart x2
Info: Executing cmd: tegrarestart, argc: 1, args: x2
Invalid Command
shell> tegrareset x1
Info: Executing cmd: tegrareset, argc: 1, args: x1
Command Executed
shell> tegrareset x2
Info: Executing cmd: tegrareset, argc: 1, args: x2
Command Executed
shell> aurixreset
ÿ
Copyright 1998-2017 Elektrobit Automotive GmbH
SystemUpInit-Time[ms]: 0
EB-DDPX-SHELL
Enter 'help' to see the available commands.
Startup Finished
shell> System_PowerOn: Reading PG status: Timeout Error!
Best regards,
Pascal Lieb
Could you please do an aurixreset and provide the output?
Fabian
Hi Fabian,
just a small hint: Look in lines 61 and following ;-)
The command output ends in line 77 with the error message provided in the log above.
Best regards,
Pascal
Could you please flash the Aurix?
Fabian
Hi Fabian, i flashed the Aurix with same result. Please check my log below.
version
DDPX Aurix Serial Console
E3550-B03
with TLF35584 B/C-Step
SW Version  1.24
Shell>status
Alive: 00:05:56
CPU0 Frequency: 300000000 Hz
STM0 Frequency: 100000000 Hz
CPU1 Frequency: 300000000 Hz
STM1 Frequency: 100000000 Hz
CPU2 Frequency: 300000000 Hz
STM2 Frequency: 100000000 Hz
Shell>showvoltages
INPUTS:
  KL30_VBAT = 12.206 V
  KL30_POWER = 12.097 V
  KL15_POWER = 12.177 V
AURIX:
  AURIX_1V3 = 1.255 V
  AURIX_3V3 = 3.332 V
  AURIX_5V = 5.002 V
  CAN1_5V = 5.036 V
  CAN2_5V = 4.989 V
  FR_5V = 5.007 V
  HRNS_GPI = 1.788 V
SYSTEM:
  VBAT_SYS = 0.394 V
  VBATSYS_ISENSE = 0.020 A
  SYS_5V = 0.018 V
  SYS_0V85 = 0.001 V
  SYS_0V92_1 = 0.001 V
  SYS_0V92_2 = 0.000 V
  SYS_1V0 = 0.001 V
  SYS_1V1_2 = 0.001 V
  SYS_1V2 = 0.001 V
  SYS_1V5_2 = 0.001 V
  SYS_1V8_1 = 0.402 V
  SYS_1V8_2 = 0.388 V
  SYS_2V1 = 0.001 V
  SYS_2V5 = 0.001 V
  SYS_3V3_1 = 0.499 V
  SYS_3V3_2 = 0.089 V
  CE_PREREG = 0.023 V
Tegra A:
  VBAT_TEG = 12.148 V
  VBATTEG_ISENSE = 0.903 A
  XA_PREREG = 11.975 V
  XA_5V = 5.096 V
  XA_5V_SW = 5.098 V
  XA_VDD_1V0 = 1.000 V
  XA_VDD_1V8_AO = 1.802 V
  XA_VDD_1V8_HS = 1.800 V
  XA_VDD_1V8_LS = 1.805 V
  XA_VDD_CPU = 0.001 V
  XA_VDD_CV = 0.001 V
  XA_VDD_DDR2 = 1.111 V
  XA_VDD_DDRQ = 0.609 V
  XA_VDD_DDR_1V1 = 1.159 V
  XA_VDD_GPU = 0.001 V
  XA_VDD_SOC = 0.846 V
  VBAT_SXMA = 0.043 V
  VBATSXMA_ISENSE = 0.010 A
  SXMA_PREREG = 0.023 V
Tegra B:
  XB_PREREG = 11.987 V
  XB_5V = 5.135 V
  XB_5V_SW = 5.141 V
  XB_VDD_1V0 = 1.002 V
  XB_VDD_1V8_AO = 1.799 V
  XB_VDD_1V8_HS = 1.802 V
  XB_VDD_1V8_LS = 1.804 V
  XB_VDD_CPU = 0.001 V
  XB_VDD_CV = 0.001 V
  XB_VDD_DDR2 = 1.115 V
  XB_VDD_DDRQ = 0.606 V
  XB_VDD_DDR_1V1 = 1.157 V
  XB_VDD_GPU = 0.001 V
  XB_VDD_SOC = 0.001 V
  VBAT_SXMB = 0.014 V
  VBATSXMB_ISENSE = 0.010 A
  SXMB_PREREG = 0.029 V
CVM:
  P1_PREREG = 12.071 V
  P1_5V = 5.106 V
Shell>pgoodstatus
XA_5V_PG = HIGH
XA_PREREG_PG = LOW
X1_PG/XA_VDD_[SOC/DDR2/DDRQ]_PG = HIGH
XA_VDD_[CPU/GPU/CV]_PG = LOW
XB_5V_PG = HIGH
XB_PREREG_PG = LOW
X2_PG/XB_VDD_[SOC/DDR2/DDRQ]_PG = LOW
XB_VDD_[CPU/GPU/CV]_PG = LOW
SYS_5V_PG = HIGH
SYS_[0V85/1V0/1V2]_PG = LOW
SYS_[3V3/1V8/0V9]_PG1 = LOW
SYS_[3V3/1V8/1V5/1V1/0V9]_PG2 = LOW
P1_5V_PG = HIGH
P1_CARRIER_PWR_ON = LOW
CIM_PWR_GD = LOW
CE_PREREG_PG = LOW
Shell>showportexp 0 1 0
EXP 0.1.0: Direction = IN; State = HIGH
Shell>showportexp 0 1 1
EXP 0.1.1: Direction = IN; State = LOW
Shell>showportexp 0 1 2
EXP 0.1.2: Direction = IN; State = LOW
Shell>showportexp 0 1 3
EXP 0.1.3: Direction = IN; State = LOW
Shell>poweroff
The board has been powered off.
Command Fail
Shell>poweron
Command Fail
Shell>
Thanks Pascal.
Please go ahead and open an internal bug since it is necessary to dig deeper from here on.
Please mention my name as PIC in the bug description at the bottom line.
Fabian
What do you mean by open an internal bug?
Raise a bug via the partners portal so we can assign our internal teams to it.
Fabian
