Hi Jerry,
EB-DrivePX-Aurix
SW Version: DRIVE-V5.0.5-P2379-EB-Aurix-With3LSS-4.02.02
Compilation date: Nov 8 2017, 16:03:03
Copyright 1998-2017 Elektrobit Automotive GmbH
Hardware information:
PMU-chip: B-Step
SCU_CHIPID: 0x4B459051
SystemUpInit-Time[ms]: 47
FPD-switch = 1 (Tegra-B)
EB-DrivePX-SHELL
Enter 'help' to see the available commands.
Startup Finished
shell> status
Info: Executing cmd: status, argc: 0, args:
Alive : 00:00:27
CPU load Core 0: 9%
CPU load max Core 0: 9%
CPU load Core 1: 0%
CPU load max Core 1: 0%
CPU load Core 2: 0%
CPU load max Core 2: 0%
PMU-chip: B-Step
IP-address (Tegra-A): 10.42.0.28
IP-address (Tegra-B): 10.42.0.29
IP-address (AURIX): 10.42.0.146
MAC-address (Tegra-A): 0x000000044B8D9ED7
MAC-address (Tegra-B): 0x000000044B8D9ED8
MAC-address (AURIX): 0x000000044B8D9ED9
MAC-address (FPGA): 0x0000000000000000
ADC0_HRNS2: 0x0934
ADC1_HRNS2: 0x0934
Command Executed
- For ttyUSB2
picocom -b 115200 /dev/ttyUSB2
picocom v1.7
port is : /dev/ttyUSB2
flowcontrol : none
baudrate is : 115200
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv
imap is :
omap is :
emap is : crcrlf,delbs,
Terminal ready
For ttyUSB6
picocom -b 115200 /dev/ttyUSB6
picocom v1.7
port is : /dev/ttyUSB6
flowcontrol : none
parity is : none
databits are : 8
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
imap is :
omap is :
Terminal ready
Ubuntu 16.04 LTS nvidia ttyS0
nvidia login:
- I am intrigued as well. I just removed the debug usb and ran lsusb again I get this
lsusb
Bus 002 Device 002: ID 8087:8002 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:800a Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 003: ID 045b:0210 Hitachi, Ltd
Bus 004 Device 002: ID 045b:0210 Hitachi, Ltd
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 045b:0209 Hitachi, Ltd
Bus 003 Device 002: ID 8087:07dc Intel Corp.
Bus 003 Device 007: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 003 Device 006: ID 046d:c063 Logitech, Inc. DELL Laser Mouse
Bus 003 Device 004: ID 045b:0209 Hitachi, Ltd
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And with debug usb I get the following
lsusb
Bus 003 Device 014: ID 0955:7018 NVidia Corp.
Bus 003 Device 013: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 012: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 011: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
When I search for the USB id get the following information
Name: T186 [Tegra Parker]. Tegra running the recovery protocol (“USB Recovery Mode” a/k/a “RCM” a/k/a “APX”) implemented by the on-chip boot ROM
Is Tegra A in a recover mode?
