when i was trying to install Driveworks 5.0.5.0, i met an error. Here is the error report,
please support to fix it. Thanks.
Aurix port /dev/ttyUSB1 does not exist
Bootburn operation unsuccessful
The following tips can help troubleshoot bootburn failures. These are based on
known issues related to setup or missing configuration. If it doesn’t help
resolve the issue, contact module owners with a copy of the full log.
Dear BjoernFathIPG,
Please double check if you have connected Host PC USB port with Drive PX2 USB 2.0 Debug port(Not Drive Px2 USB 3.0 port) before flashing. After connecting, ls /dev/ttyUSB* should list 8 devices.
yes, i checked there are 8 devices ttyUSB 0-7 have been found. but during flashing, these 8 ports will disappear from the list. i am assuming maybe it is the cable issue. have you met this cable issue before?
I am having difficulties with the flashing of DRIVE 5.0.10.3 SDK WITH DRIVEWORKS LINUX FOR DRIVE PX 2 AUTOCHAUFFEUR.
Unsuccessful in flashing Tegra A or Tegra B or together.
From error report,
Target will be flashed with rootfs in eMMC
Aurix Port = /dev/ttyUSB1
Successfully acquired lock over /var/lock/LCK..bootburn_seq
Successfully acquired lock over /var/lock/LCK..ttyUSB1
Disabling SIGINT <Ctrl+C> temporarily
Setting Tegra-A on hold…cat: /dev/ttyUSB1: Resource temporarily unavailable
Could not execute command “tegrareset a h” on aurix. Log follows,
error-aurix-command
Unable to restore Aurix Console Params
error= error-aurix-command
The Aurix console did not regognize the command given to it. Please review
the logs and make sure that the command that you are sending is valid
bootburn flashing failed! error code = 37
“ls /dev/ttyUSB*” gives me 8 devices
For your assistance please.
further details:
Host information:
OS : ubuntu 16.04 LTS 64-bit
uname -a → [ Linux cetranpx2-OptiPlex-7040 4.15.0-45-generic #48~16.04.1-Ubuntu SMP Tue Jan 29 18:03:48 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux ]
hostname -I → [ 172.21.76.1 ]
Target information:
Tegra B
uname -a → Linux nvidia 4.4.38-rt49-tegra #1 SMP PREEMPT RT Tue Jul 25 09:26:02 PDT 2017 aarch64 aarch64 aarch64 GNU/Linux
Dear Mohd.azhar,
notice issues with ubuntu 16.04 with latest kernels. We are working to fix this issue. Could you please check with ubuntu 14.04 host or with downgrade your linux kernel version( ex. 4.15.0-32) and check installing?
I have initially installed Ubuntu 18.04 and later downgraded to 16.04 after seeing the documentation that DPX2 can only be flashed with 14.04 or 16.04. Now, I have to again downgrade to install DPX2. Is there any other fix than this?.
