Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
other
Host Machine Version
native Ubuntu 18.04
other
Hi There,
Here we have situation with xavier for long time.
Hardware: T194A/B
Main issue:
Xavier was working with SW9.0, and working well, but it was crashed now, problem as below:
Xavier A not able to book, we can reflash the xaiver with ubuntu16 and SW9.0 environment (upgrade the python to 3.7 with pip 3.7) to reflash it with option to reflash xavier A, output is still xaiver A desktop picture from HDMI XavierB. (this is because ttyUSB2 is not accessable, while ttyUSB3, ttyUSB6 are all accessable)
Then we tried to reflash the aurix with windows infineon software , seems it works, the firmware we were using as below:
DRIVE-V5.1.0-E3550-NV-Aurix-IFW-StepA-1.29.00
DRIVE-V5.1.0-E3550-NV-Aurix-UPDATE-StepA-1.29.00
DRIVE-V5.1.0-E3550-EB-Aurix-With3LSS-3.02.07
DRIVE-V5.1.0-P3479-EB-Aurix-With3LSS-3.02.07
DRIVE-V5.1.0-P3479-NV-Aurix-UPDATE-StepA-1.29.00
but could not resolve the problem.
we tried to reflash the different version including 10.0, 5.2.6, seems was successfully, but was only for XavierB as well, xavier A always not able to book.
- Now recently all the version reflash failed, we can’t access all the USB port including ttyUSB 2.3.6, but with ubuntu 18, seems when reflash 5.2.6, USB3 is still accessable (not sure, will post some information later).
And also always when you poweroff the xavier, you can’t poweron same day, always waiting for the next day to poweron it (poweron here means fan works, LED on board flashing continuely), minutes later, the IP from router terminal list will dispear (seems it’s dead again), but before that, may able to access via minicom -D /dev/ttyUSB3.
- currently SW9.0 with ubuntu 16 log as below:
6:47:30 DEBUG: running command < true >
16:47:30 INFO: command finished successfully
16:47:30 DEBUG: running command < stat /dev/ttyUSB3 >
16:47:30 DEBUG: running command < true >
16:47:30 DEBUG: running command < lsof /dev/ttyUSB3 2>/dev/null >
16:47:31 DEBUG: command terminated with error
16:47:31 DEBUG: running command < true >
16:47:31 INFO: command finished successfully
16:47:31 DEBUG: Flash Xavier A - flash: using adapter to install NV_FLASH_XAVIER_PDKFLASH_A_COMP@DDPX to /media/jason/data/NVIDIA-SW9/DW9SDK/DRIVE_Software_9.0_Linux_hyperion_DRIVE_AGX_XAVIER
16:47:31 INFO: Flash Xavier A - flash: Installing component 'Flash Xavier A' (NV_FLASH_XAVIER_PDKFLASH_A_COMP)
16:47:31 INFO: Flash Xavier A - flash: exec_command: cd pdkinstaller && ./bin/python3 -E ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /media/jason/data/NVIDIA-SW9/DW9SDK/DRIVE_Software_9.0_Linux_hyperion_DRIVE_AGX_XAVIER/DriveSDK --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraA_install_config.json --consoleout enable
16:49:32 INFO: Flash Xavier A - flash: Password for jason:
16:49:32 ERROR: Flash Xavier A - flash: command terminated with error
16:49:32 SUMMARY: Flash Xavier A - flash: First Error: Installation failed.
we changed the 2nd power supply, issue is similar, seems it’s not power supply issue. voltage is as below
BTW, once we can access the xavier via putty terminal, always USB14 is accesable, not USB4, minicom configuration is not sure in right status or not.
appreciate if anyone can help to solve the issue.
