When I reboot nebra using aurixreset, in some of the tries I see that Xavier boards boot but then fails to respond after a few seconds. I can’t ping it and also access it via the debug cable. There is nothing interesting in /var/log/syslog and also nothing fails in calling aurixreset.
I thought that this might be somehow related to the aurix firmware or the hardware.
To update the firmware I went through this document and tried:
- Making all .sh files in /etc/systemd/scripts/ executable because some of them were not executable by default
- Running
sudo /bin/bash /etc/systemd/scripts/nv_aurix_check_fw.sh -auto_updatebut it failed:
$ sudo /bin/bash /etc/systemd/scripts/nv_aurix_check_fw.sh -auto_update
[sudo] password for nvidia:
starting Aurix FW checking...
Checking arguments...
No_Response_From_Aurix
!!! IMPORTANT INFORMATION BELOW REGARDING Aurix FW (PLEASE READ) !!!
No response from Aurix FW. It seems
vlan iface not configured properly
Please check your nv_tacp_init systemd service
THIS MESSAGE WILL CONTINUE TO BE SHOWN UNTIL ACTION MENTIONED IS TAKEN
With action taken, this script will be muted and not shown again
Also in aurix shell I can see some errors reported using showsafetylogs. not sure if they are relevant:
NvShell>showsafetylogs
Info: Executing cmd: showsafetylogs, argc: 0, args:
Tegra and MCU 3LSS version mismatch for Device ID 0!!!
Device ID 2, FuSa State Changed : FUSA_ERROR_STATE
Error Notification received
Device ID : 2
Extended Error Id : 0x3100011
EEP Timestamp : 549755814016
Error Status : ERROR DETECTED
Error Info Size: 0
Error Info :
Device ID : 2
Extended Error Id : 0x3100012
Error Info Size: 0
Error Info :
Unable to read Startup FuSa State
Tegra and MCU 3LSS version mismatch for Device ID 1!!!
Safety Services FuSa State : FUSA_ERROR_STATE
Command Executed
I’ve also seen some forum posts that were using showvoltages command but seems this is not available in my aurix shell. so I have no way to check chips voltages. Might be related to my current firmware version(DRIVE-V5.2.0-E3550-AFW-Aurix-With3LSS-StepA-4.02.02)?
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.0.8170
1.5.1.7815
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
