Software Version [I’m not sure]
Target Operating System[Linux]
Hardware Platform[NVIDIA DRIVE™ AGX Xavier DevKit (E3550)]
SDK Manager Version[1.4.0.7363]
Host Machine Version[native Ubuntu 18.04]
I have been having issues with my Drive AGX where I can’t connect it to the ethernet for months and I have been able to use it. I decided to completely start over and reinstall ubuntu on the host computer and try downloading the SDK Manger again and trying to reflash the AGX hoping that this would fix my problem. Last week I thought that I was able to reflash the AGX but Xavier doesn’t seem to boot up. The light by the debugging port is on and the fans for the motherboard are also on but there isn’t any signal coming from the HDMI ports. I tried reflashing the AGX a couple of time again through the GUI and the command line (probably doesn’t make a difference) and the AGX is still not booting up. I think it might be in some kind of recovery mode but I’m not sure how to get it back into normal mode. Also, I don’t think the AGX is reflashing correctly. The SDK manager says that Flash for Xavier A+B was Skipped. Any advice for this issue is greatly appreciated. Like I said, it has been over a month since we haven’t been able to use this computer.
Output from SDK manager in the latest flashing attempt:
Authenticating with NVIDIA server…
Login succeeded.
Loading user information…
User information loaded successfully.
Loading server data…
Server data loaded successfully.
Session initialized…
===== INSTALLATION COMPLETED SUCCESSFULLY. =====
- CUDA on Host: Up-to-date
- CUDA Cross-Compile for Linux: Up-to-date
- cuDNN x86: Up-to-date
- cuDNN Cross-Compile for Linux: Up-to-date
- TensorRT x86: Up-to-date
- TensorRT Cross-Compile for Linux: Up-to-date
- CMAKE build utility: Up-to-date
- NVIDIA Nsight Graphics: Installed
- NVIDIA Nsight Systems: Installed
- GNU Toolchains: Up-to-date
- DRIVE Foundation Packages: Up-to-date
- DRIVE Foundation OSS Packages: Up-to-date
- P3479 Specific Package: Up-to-date
- E3550 Specific Package: Up-to-date
- Flash Tools: Up-to-date
- OSS Packages: Up-to-date
- OSS Source Packages: Up-to-date
- NV Packages: Up-to-date
- File System: Up-to-date
- File System Tools: Up-to-date
- DRIVE OS Linux SDK Documentation: Up-to-date
- Flash Xavier A+B in parallel: Installed
- Flash Xavier A: Skipped
- Flash Xavier B: Skipped
===== Installation completed successfully - Total 24 components =====
===== 3 succeeded, 0 failed, 19 up-to-date, 2 skipped =====
Thank you,
Zeus
