Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
NVIDIA DRIVE™ Software 8.0 (Linux)
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.0.10363
1.6.1.8175
other
Host Machine Version
native Ubuntu 18.04
native Ubuntu 16.04
other
I have a DRIVE AGX Xavier (PN: 940-63550-2000-100) that is still running the original software it was shipped with. I am looking to upgrade this to latest DRIVE OS 5.2.6. The release notes indicate I must upgrade step-by-step from previous releases. So 5.2.6. says it can upgrade from DRIVE Software 10.0. 10.0 says must upgrade from 9.0. 9.0 says must upgrade from 8.0. I believe this unit is running DRIVE Software 1.0 from below info:
Aurix console:
shell> version
Info: Executing cmd: version, argc: 0, args:
SW Version: DRIVE-V5.0.10-E3550-EB-Aurix-With3LSS-ForHyperion-3.00.07
Compilation date: Jul 20 2018, 09:08:33
Command Executed
Tegra-B:
apex@pa-dev-drvagx-01-b:~$ cat /etc/nvidia/version-ubuntu-rootfs.txt
5.0.10.3-12606092
apex@pa-dev-drvagx-01-b:~$ uname -a
Linux pa-dev-drvagx-01-b 4.9.80-rt61-tegra #1 SMP PREEMPT RT Tue Sep 4 11:02:44 PDT 2018 aarch64 aarch64 aarch64 GNU/Linux
apex@pa-dev-drvagx-01-b:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="16.04.7 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.7 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
After a lot of reading through the forums, I found that I need the host device running native Ubuntu 16.04 and that SDK Manager must be version 1.6.1. Additionally to get SDK Manager to allow flashing older software versions, I must run SDK Manager like ‘sdkmanager --archivedversions’. After all this I’m able to select ‘DRIVE Software 8.0’ as a target OS. I accept agreement and choose to download and install later. This ends up failing showing a ‘download error’ on several packages. Similar occurs on Software 9.0. Tried on two different Ubuntu 16.04 hosts and same errors.
I tried accessing one of the failed URL on local browser and just get ‘file not found’ message. Seems like these older DRIVE versions are now missing some files.
Am I missing something to download either Software 8.0 or 9.0?
Or maybe different question is what is recommended steps to get this unit upgraded from DRIVE Software 1.0 to DRIVE OS 5.2.6?
Can I skip Software 8.0 & 9.0 and flash Software 10.0 from Ubuntu 18.04 host? Software 10.0 does download successfully on an Ubuntu 18.04 host. However the 10.0 release notes say you can only upgrade from DRIVE Software 9.0.
Lamar
