Sdkmanager downgrade to Drive 10.0 fails
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
I have a xavier board with 5.2.0 installed and I want to downgrade to 5.1.6.1. I have followed instructions to downgrade Aurix from this link and that seems to work fine, but when I try to flash board it fails building the system image. I have updated sdkmanager to latest 1.6.1.8175 which seems to have caused redownload of entire 5.1.6.1 code base (DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER), however the same PC used to work with flashing 5.1.6.1 before (using DRIVE_Software_10.0_Linux_OS_DDPX directory).
error screen
logs from ~/.nvsdkm
nvsdkm.tar.xz (1.4 MB)
Aurix console:
shell> version
Info: Executing cmd: version, argc: 0, args:
SW Version: DRIVE-V5.1.6-E3550-EB-Aurix-With3LSS-ForHyperion-StepA-3.05.04
Compilation date: Jun 25 2019, 14:25:36
Command Executed
Dear @gordon1zrra,
I notice error: file downloaded with wrong checksum in the logs. Please uninstall old DRIVE SW using sdkmanager and remove ~/.nvsdkm folder. Please check fresh installation of DRIVE SW 10.0 and share the logs if you hit any issue.
It’s strange, I don’t see the correct Drive SW in the Repair/Uninstall Menu.
From the Main screen, it shows Drive 10.0 rev2
But from Uninstall it shows Drive 10.0 rev1 but no rev2:
Is there a way to manually erase Drive 10.0 rev2?
Hi @gordon1zrra,
This looks correct.
I saw below messages in your latest log and it seems to fail in applying patches.
Please try “rm -rf /home/gordon/storage/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS” and then reinstall DRIVE Software 10 with SDK Manager.
18:48:13.107 - info: NV_DPX_PACKAGES_COMP@DDPX: change working directory to /home/gordon/storage/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS
18:48:13.107 - info: NV_DPX_PACKAGES_COMP@DDPX: .install/ folder from previously installed component exists and is being removed
8:48:13.111 - info: NV_DPX_PACKAGES_COMP@DDPX: exec_command: /home/gordon/storage/nvidia_download/drive-t186ref-linux-5.1.6.1-16911241-dpx-patch-v0.7.run
18:48:15.427 - info: NV_DPX_PACKAGES_COMP@DDPX: Linux/5.1.6.1_2144485.patch
18:48:15.445 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh
18:48:15.445 - info: NV_DPX_PACKAGES_COMP@DDPX: Reversed (or previously applied) patch detected! Assume -R? [n]
18:48:15.446 - info: NV_DPX_PACKAGES_COMP@DDPX: Apply anyway? [n]
18:48:15.446 - info: NV_DPX_PACKAGES_COMP@DDPX: Skipping patch.
18:48:15.458 - info: NV_DPX_PACKAGES_COMP@DDPX: 13 out of 13 hunks ignored – saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh.rej
18:48:15.458 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh
18:48:15.459 - info: NV_DPX_PACKAGES_COMP@DDPX: Reversed (or previously applied) patch detected! Assume -R? [n]
18:48:15.459 - info: NV_DPX_PACKAGES_COMP@DDPX: Apply anyway? [n]
18:48:15.459 - info: NV_DPX_PACKAGES_COMP@DDPX: Skipping patch.
18:48:15.460 - info: NV_DPX_PACKAGES_COMP@DDPX: 14 out of 14 hunks ignored – saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh.rej
18:48:15.460 - info: NV_DPX_PACKAGES_COMP@DDPX: patching file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/create_bsp_images.sh
18:48:15.460 - info: NV_DPX_PACKAGES_COMP@DDPX: Reversed (or previously applied) patch detected! Assume -R? [n]
18:48:15.460 - info: NV_DPX_PACKAGES_COMP@DDPX: Apply anyway? [n]
18:48:15.461 - info: NV_DPX_PACKAGES_COMP@DDPX: Skipping patch.
18:48:15.461 - info: NV_DPX_PACKAGES_COMP@DDPX: 2 out of 2 hunks ignored – saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/create_bsp_images.sh.rej
18:48:15.461 - info: NV_DPX_PACKAGES_COMP@DDPX: [ Package Install Finished with Error ]
18:48:15.462 - info: NV_DPX_PACKAGES_COMP@DDPX: [host] [ 44.00 KB used. Disk Avail: 70.98 GB ]
18:48:15.462 - info: NV_DPX_PACKAGES_COMP@DDPX: [ NV_DPX_PACKAGES_COMP Install took 2s ]
18:48:15.462 - error: NV_DPX_PACKAGES_COMP@DDPX: [error]: [exit_code]: 1: [exec_command]: /bin/bash -c /home/gordon/storage/nvidia_download/drive-t186ref-linux-5.1.6.1-16911241-dpx-patch-v0.7.run | tee -a /home/gordon/.nvsdkm/logs/DRIVE_Software_10.0_Linux_OS/NV_DPX_PACKAGES_COMP.log; exit ${PIPESTATUS[${#PIPESTATUS[@]}-2]}; [error_message]: No stderr available, the last line from stdout is: 2 out of 2 hunks ignored – saving rejects to file drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/create_bsp_images.sh.rej
I removed the directory, and tried to flash after restarting PC and xavier, but getting similar error. Note, on Step 2 it still shows packages as already downloaded.
Log files:
nvsdkm.tar.xz (736.8 KB)
I was trying to check the patch error, it seems when I deleted the DRIVEOS directory, during the re-install it did not unpack the drive-t186ref-foundation nor any other directories. I only see a .install directory and some patch files.
DRIVEOS$ pwd
DRIVEOS$ ls -la
total 60
drwxr-xr-x 3 gordon gordon  4096 Sep 22  2019 .
drwxrwxr-x 4 gordon gordon  4096 Sep 14 10:38 ..
-rw-r--r-- 1 gordon gordon   789 Sep 14 10:56 5.1.6.1_2128000.patch
-rw-r--r-- 1 gordon gordon 20478 Sep 14 10:56 5.1.6.1_2139720.patch
-rw-r--r-- 1 gordon gordon  1338 Sep 14 10:56 5.1.6.1_2165317.patch
-rw-r--r-- 1 gordon gordon  6180 Sep 14 10:56 5.1.6.1_2166497.patch
-rw-r--r-- 1 gordon gordon  3909 Sep 14 10:56 5.1.6.1_2167188.patch
-rw-r--r-- 1 gordon gordon   661 Sep 14 10:56 5.1.6.1_2168250.patch
-rw-r--r-- 1 gordon gordon  1200 Sep 14 10:56 5.1.6.1_2189571.patch
drwxr-xr-x 3 gordon gordon  4096 Sep 22  2019 .install
Yeah, saw error still at 5.1.6.1_2144485.patch.
10:38:30.494 - info: NV_DPX_PACKAGES_COMP@DDPX: Linux/5.1.6.1_2144485.patch
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: can’t find file to patch at input line 5
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: Perhaps you used the wrong -p or --strip option?
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: The text leading up to this was:
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: --------------------------
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: |diff --git a/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh b/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: |index a18a40b…22d0188 100755
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: |— a/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: |+++ b/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn.sh
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: File to patch:
10:38:30.511 - info: NV_DPX_PACKAGES_COMP@DDPX: Skip this patch? [y]
10:38:30.512 - info: NV_DPX_PACKAGES_COMP@DDPX: Skipping patch.
10:38:30.514 - info: NV_DPX_PACKAGES_COMP@DDPX: 13 out of 13 hunks ignored
10:38:30.514 - info: NV_DPX_PACKAGES_COMP@DDPX: can’t find file to patch at input line 232
Please rm -rf ~/.nvsdkm ~/nvidia/nvidia_sdk* and then try if installing to the default directory (~/nvidia/nvidia_sdk instead of /home/gordon/storage/nvidia_sdk) helps.
It’s not really possible to install to default directory since I’m out of hard drive space. Would it work if I made it a symlink from ~/nvidia_sdk to ~/storage/nvidia_sdk?
Let’s focus on this now. I’ll check with our team and get back to you.
Finally, some good news. After I made the symlink to ~/nvidia_sdk, the unpacking worked and the patch passed, however it failed prior to the flashing step a few times but eventually after a few retries it worked.
Good to hear it was sovled.
