I cannot flash xavier B anymore, it will failed immediately
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
I am trying to flash xavier B on Drive AGX, but it will fail immediately
This is the error I am getting. Can you please help?
13:39:21 DEBUG: Flash Xavier B - flash: using adapter to install NV_DRIVE_FLASH_DDPX_X2_COMP@DDPX to /home/ubuntu/Documents/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/
13:39:21 INFO: Flash Xavier B - flash: exec_command: /tmp/tmp_NV_DRIVE_FLASH_DDPX_X2_COMP.sh
13:39:21 INFO: Flash Xavier B - flash: exec_command: sudo rm -f /var/lock/LCK…ttyUSB3 /var/lock/LCK…bootburn_seq /var/lock/LCK…bootburn
13:39:21 INFO: Flash Xavier B - flash: [ Package Install Started ]
13:39:21 INFO: Flash Xavier B - flash: #Program the Local Temperature High Limit for ALERT
13:39:21 INFO: Flash Xavier B - flash: The user ubuntu' is already a member of dialout’.
13:39:21 INFO: Flash Xavier B - flash: --wipe-persistent-partition
13:39:21 INFO: Flash Xavier B - flash: host sudo password for ubuntu:
13:39:22 INFO: Flash Xavier B - flash: [target] target sudo password for nvidia:
13:39:22 INFO: Flash Xavier B - flash: Auto detecting target Aurix port …
13:39:28 INFO: Flash Xavier B - flash: BOARD SKU : 940-63550-2000-100
13:39:28 INFO: Flash Xavier B - flash: Executing bind clean cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194b clean
13:39:28 INFO: Flash Xavier B - flash: Executing bind cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194b
13:39:32 INFO: Flash Xavier B - flash: Pre flash script found! Calling scripts/linux_pre_flash.sh
13:39:40 INFO: Flash Xavier B - flash: BOARD SKU : 940-63550-2000-100
13:39:40 INFO: Flash Xavier B - flash: Running flash command: sudo -E /home/ubuntu/Documents/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh -b e3550b03-t194b -B qspi -x /dev/ttyUSB3
13:39:49 INFO: Flash Xavier B - flash: bootburnLib.BootRCM(“rcm-flash”, targetConfig.p_OutDirPath)
13:39:49 INFO: Flash Xavier B - flash: pdkinstaller cannot continue! Check the log file for details: /home/ubuntu/Documents/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/pdkinstaller/pdkinstaller.log
13:39:49 INFO: Flash Xavier B - flash: [host] [ 4.39 MB released. Disk Avail: 29.74 GB ]
13:39:49 ERROR: Flash Xavier B - flash: command terminated with error
13:39:49 SUMMARY: Flash Xavier B - flash: First Error: Installation failed.
Kindly share the logs from your ~/.nvsdkm/ directory for us to examine. While waiting for that, could you try reflashing after restarting your host system and confirming at USB 2.0 speed?
Hi
I attached ~/.nvsdkm directory. I tried reflashing after restarting my host system and it is USB 2.0 speed.
nvsdkm.zip (1.4 MB)
Thank you,
Thank you for sharing the ~/.nvsdkm directory. Could you kindly share the log located at the specified path so we can take a look?
~/ubuntu/nvidia/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples_DRIVE_AGX_XAVIER/DRIVEOS/pdkinstaller/pdkinstaller.log
This is the log,
pdkinstaller.log (208.3 KB)
Thank you.
I came across some error messages in the log file. I’ll consult with my team on this. In the meantime, could you follow the installation guide and attempt to flash using Docker?
[2023-02-02 17:20:52,822 root INFO pdk_bind.py 169 12075] Executing bind clean cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194b clean
[2023-02-02 17:20:52,826 root DEBUG pdk_bind.py 192 12075] Bind partitions failed !
File “module/pdk_bind.py”, line 176, in pdk_bind
File “subprocess.py”, line 311, in check_call
subprocess.CalledProcessError: Command ‘make -f Makefile.bind PCT=linux BOARD=e3550b03-t194b clean’ returned non-zero exit status 2.
[2023-02-02 17:20:52,827 root ERROR pdk_bind.py 193 12075] Binding of partitions failed ! Check log for more details.
[2023-02-02 17:20:52,827 root DEBUG pdk_bind.py 42 12075] Makefile.bind:23: .cross_compile: No such file or directory
[2023-02-02 17:20:52,827 root DEBUG pdk_bind.py 42 12075] Makefile.bind:37: *** CROSS_COMPILE is not defined!. Stop.
[2023-02-02 17:20:52,827 root INFO runner.py 37 12075] Failed to bind partitions!
[2023-02-02 17:20:52,827 root DEBUG runner.py 39 12075] Error on line 866
[2023-02-02 17:20:52,827 root DEBUG runner.py 40 12075] Exception info: Exception Type <class ‘module.errors.FailedToBindPartitionsError’>, Traceback <traceback object at 0x7f031a046508>
Thank you for the suggestion. I tried it and getting the following error:
source $(dirname “${BASH_SOURCE[0]}”)/drive_flashing/startup.sh
root@ubuntu-System-Product-Name:/drive# ./flash.sh --tegra=“B”
Executing Bind
Preparing to Flash Tegra B
PDK Installer failed with status 144
FlashTegraPDKInstaller failed, error 144!
Error 144 occurred, please resolve the issue or try again.
Please contact provider with log “/drive_flashing/log_5a9045b85763d862aea477fcb4a248f6.txt”.
log_5a9045b85763d862aea477fcb4a248f6.txt (7.9 KB)
Thank you for your help and support.
Thank you VickNV, flashing was successful using Docker.
But can you please let me know the root cause of flashing using sdkmanager failed?
Great to hear that the flashing was successful using Docker. We will investigate the root cause of the failure using sdkmanager and update you with our findings.
Dear @user158496,
Could you please remove ~/.nvsdkm/ folder and check uninstall the driveos 5.2.6 using sdkmanager and check installing again? Please share ~/.nvsdkm/logs and ~/.nvsdkm/sdkm*.log if you face any issue…
Dear @user158496,
Did you get a chance to test above ask?
Hi SivaRama,
I haven’t tried it yet since flashing using docker works.
I will let you know as soon as I try it.
Thank you
Hi SivaRama,
It works, I uninstall it and flash it using sdkmanager.
Thank you,
