Hello
When I falsh the “Flash Xavier A+B in parallel - flash” to “NVIDIA DRIVE™ AGX Xavier DevKit (E3550)”, occured some errors as follow:
08:05:44 ERROR: Flash Xavier A+B in parallel - flash: [exec_command]: /bin/bash -c cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable; [error]:
08:05:44 ERROR: Flash Xavier A+B in parallel - flash: command terminated with error
08:05:44 SUMMARY: Flash Xavier A+B in parallel - flash: First Error: Installation failed.
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[yes] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[yes] Linux
QNX
other
Hardware Platform
[yes] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.9.1.10844
[yes] other 2.1.0.11660 x86_64
Host Machine Version
native Ubuntu 18.04
other
VickNV
April 1, 2024, 5:29pm
5
Here is a snippet from your logs. Please see if the solution provided in this forum thread helps with your issue: DRIVE Softare 10.0 flashing failed for AGX Xavier kit
08:05:39.975 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: command options used = -b e3550b03-t194 -B qspi -x /dev/ttyUSB3 --updtcfga gos1-fs:dirname:/home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/targetfs_a --updtcfgb gos1-fs:dirname:/home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-linux/targetfs_b -w^M
08:05:39.975 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: ^M
08:05:39.975 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: ------------ Stack Trace ------------^M
08:05:39.976 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 0 - 329 AbnormalTermination /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh^M
08:05:39.977 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 1 - 2394 GenerateRcmMessage /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh^M
08:05:39.978 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 2 - 2494 GenerateAllRcmMessage /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh^M
08:05:39.978 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 3 - 3141 BootRCM /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_lib.sh^M
08:05:39.978 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 4 - 401 source /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/bootburn_active.sh^M
08:05:39.979 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: stack frame 5 - 1270 main /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation//tools/host/flashtools/bootburn_t19x/bootburn.sh^M
08:05:39.979 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: -------------------------------------^M
08:05:39.980 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: ^M
08:05:39.980 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: Tool OutPut:^M
08:05:39.981 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: sh: 1: python: not found^M
08:05:39.981 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: start nvimagegen^M
08:05:39.981 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: arguments: /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/../../../..//tools/host/flashtools/flash/nvimagegen --chip 0x19 --chipver A02 --signbin mb1_recovery.bin^M
08:05:39.982 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: Signing binary mb1_recovery.bin^M
08:05:39.982 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: SignBinary : 434: Error ResourceError (0x9)^M
08:05:39.983 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: tegrasign invokation failied:[E]: SignBuffer : 520: Error ResourceError (0x9)^M
08:05:39.983 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: AppendGenHeaderSignBufferT19x : 257: Error ResourceError (0x9)^M
08:05:39.983 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Error in signing Binary with SHA256:[E]: WriteBufferToFile : 86: Error FileWriteFailed (0xf)^M
08:05:39.984 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Unable to write to file mb1_recovery_zerosign.bin^M
08:05:39.984 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: AppendGenHeaderSignBianry : 303: Error FileWriteFailed (0xf)^M
08:05:39.985 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Unable to write to mb1_recovery_zerosign.bin:[E]: AppendGenHeaderSignSpecificBinaryT19x: 352: Error FileWriteFailed (0xf)^M
08:05:39.985 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: Tool OutPut to stderr:^M
08:05:39.985 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: sh: 1: python: not found^M
08:05:39.986 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: start nvimagegen^M
08:05:39.986 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: arguments: /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/../../../..//tools/host/flashtools/flash/nvimagegen --chip 0x19 --chipver A02 --signbin mb1_recovery.bin^M
08:05:39.987 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: Signing binary mb1_recovery.bin^M
08:05:39.987 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: SignBinary : 434: Error ResourceError (0x9)^M
08:05:39.987 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: tegrasign invokation failied:[E]: SignBuffer : 520: Error ResourceError (0x9)^M
08:05:39.988 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: AppendGenHeaderSignBufferT19x : 257: Error ResourceError (0x9)^M
08:05:39.988 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Error in signing Binary with SHA256:[E]: WriteBufferToFile : 86: Error FileWriteFailed (0xf)^M
08:05:39.989 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Unable to write to file mb1_recovery_zerosign.bin^M
08:05:39.989 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: AppendGenHeaderSignBianry : 303: Error FileWriteFailed (0xf)^M
08:05:39.989 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: :[E]: Unable to write to mb1_recovery_zerosign.bin:[E]: AppendGenHeaderSignSpecificBinaryT19x: 352: Error FileWriteFailed (0xf)^M
08:05:39.990 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: error-tool-nvimagegen^M
08:05:39.990 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: ^M
08:05:39.991 - info: NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX: ==> /home/ai/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x/_temp_dump/TegraALog_AJHEYn6VaQ.txt <==
system
Closed
May 23, 2024, 6:45pm
8
