Software Version
DRIVE OS Linux 5.2.0
[*] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[*] 1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
[*] other (Virtual Machine: VmWare Ubuntu 18.04)
Hi everyone, I’m posting this message today because I am facing a problem/ an error when I try to flash xavier A+B.
As you can see in the picture below, all my Os images are ready but when I want to flash it stops at 7%:
This is what I have in the terminal:
06:17:48 DEBUG: Flash Xavier A+B in parallel - flash: using adapter to install NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP@DDPX to /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX
06:17:48 INFO: Flash Xavier A+B in parallel - flash: [host] [ Disk Avail:7.85 GB ]
06:17:48 INFO: Flash Xavier A+B in parallel - flash: Installing component ‘Flash Xavier A+B in parallel’ (NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP)
06:17:48 INFO: Flash Xavier A+B in parallel - flash: change working directory to /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS
06:17:48 INFO: Flash Xavier A+B in parallel - flash: [ Component PreInstall Started ]
06:17:48 INFO: Flash Xavier A+B in parallel - flash: current working directory is /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS
06:17:48 INFO: Flash Xavier A+B in parallel - flash: exec_command: sudo /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DriveSW_Components/DrivePlatform/tools/targetfs_passwd.sh /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS {{TARGET_PASSWORD}}
06:17:48 INFO: Flash Xavier A+B in parallel - flash: [host] [sudo] password for hostpc:
06:17:49 INFO: Flash Xavier A+B in parallel - flash: Setting new password in /pdk_install_dir/drive-t186ref-linux/targetfs_a
06:17:49 INFO: Flash Xavier A+B in parallel - flash: Setting new password in /pdk_install_dir/drive-t186ref-linux/targetfs_b
06:17:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: [ -e /dev/ttyUSB3 ] || echo Failed to flash device: detected no board connected to host with USB cable. >&2
06:17:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: sudo rm -f /var/lock/LCK…ttyUSB3 /var/lock/LCK…bootburn_seq /var/lock/LCK…bootburn
06:17:50 INFO: Flash Xavier A+B in parallel - flash: [ Component PreInstall Finished Successfully ]
06:17:50 INFO: Flash Xavier A+B in parallel - flash: [ Component Install Started ]
06:17:50 INFO: Flash Xavier A+B in parallel - flash: current working directory is /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS
06:17:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: sudo adduser `whoami | tr -d ’
06:17:50 INFO: Flash Xavier A+B in parallel - flash: '` dialout
06:17:50 INFO: Flash Xavier A+B in parallel - flash: The user hostpc' is already a member of dialout’.
06:17:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: sudo chmod a+rw /dev/ttyUSB*
06:17:50 INFO: Flash Xavier A+B in parallel - flash: exec_command: cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable
06:19:50 INFO: Flash Xavier A+B in parallel - flash: Password for hostpc:
06:19:50 INFO: Flash Xavier A+B in parallel - flash: This script must be run with root privileges!
06:19:50 INFO: Flash Xavier A+B in parallel - flash: pdkinstaller v2.0
06:19:50 INFO: Flash Xavier A+B in parallel - flash: SDK/PDK Installer and Flasher
06:19:50 INFO: Flash Xavier A+B in parallel - flash: Run ./pdkinstaller --help for usage information.
06:19:50 INFO: Flash Xavier A+B in parallel - flash: Initializing board and OS configuration to Autonomous Vehicle DDP Pegasus Hyperion-7.1 Linux Tegra AB
06:19:50 INFO: Flash Xavier A+B in parallel - flash: Manifest version 2.0
06:19:50 INFO: Flash Xavier A+B in parallel - flash: AURIX port for board e3550-t194 not found! Please check if board is connected.
06:19:50 INFO: Flash Xavier A+B in parallel - flash: Aurix port not found! Please check if board is connected.
06:19:50 INFO: Flash Xavier A+B in parallel - flash: pdkinstaller cannot continue! Check the log file for details: /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/pdkinstaller/pdkinstaller.log
06:19:50 INFO: Flash Xavier A+B in parallel - flash: [ Component Install Finished with Error ]
06:19:50 INFO: Flash Xavier A+B in parallel - flash: [host] [ 28.00 KB used. Disk Avail: 7.85 GB ]
06:19:50 INFO: Flash Xavier A+B in parallel - flash: [ NV_FLASH_XAVIER_PDKFLASH_PARALLEL_COMP Install took 2m3s ]
06:19:50 ERROR: Flash Xavier A+B in parallel - flash: [error]: : [exec_command]: /bin/bash -c cd pdkinstaller && ./pdkinstaller --installtype bindflash --boardtype ES --pdkinstalledpath /home/hostpc/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS --configjson ./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json --consoleout enable; [error]:
06:19:50 ERROR: Flash Xavier A+B in parallel - flash: command terminated with error
06:19:50 SUMMARY: Flash Xavier A+B in parallel - flash: First Error: Installation failed.
But I’ve checked and the board is connected and also recognized when I launch the SdkManager…
