Dear @gabig,
Did you connect the board to host PC via Debug USB cable?
I could see “Error is: Failed to flash device: detected no board connected to host with USB cable” in sdkm.log".
OK did it, flash ended successfully.
I compiled driveworks samples to AGX successfully as explained in your youtube video and try to run egomotion sample.
But the sample_egomotion is not running and i get the following error message:
nvidia@tegra-ubuntu:~/drive-t186ref-linux/samples$ ./sample_egomotion
libEGL warning: DRI3: failed to query the version
libEGL warning: DRI2: failed to authenticate
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 154 ()
Minor opcode of failed request: 1
Serial number of failed request: 100
Current serial number in output stream: 100
Dear @gabig,
It seems you able to flash the board and filed another topic for new issue at Error running egomotion sample on Drive. Lets close this topic and continue the discussion in new thread
