I can’t flash the Drive using the USB connection.
This is the pdkinstaller.log:
[code][2019-06-05 13:57:52,386 root DEBUG log_setup.py 67 2566] Logging to file: /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/pdkinstaller/pdkinstaller.log
[2019-06-05 13:57:52,386 root DEBUG log_setup.py 69 2566] This log is being continued by a new invocation of pdkinstaller!
[2019-06-05 13:57:52,386 root INFO pdkinstaller 650 2566] pdkinstaller v2.0
SDK/PDK Installer and Flasher
Run ./pdkinstaller --help for usage information.
[2019-06-05 13:57:52,386 root DEBUG pdkinstaller 656 2566] Parsed CLI arguments: Namespace(board_name=None, board_type=‘ES’, chip_revision=None, config_file=None, config_json=‘./manifests/install_pdk_config/av_ddp_pegasus_hyp71_linux_tegraAB_install_config.json’, csle_out=‘enable’, fnd_path=None, git_top_path=‘’, host_env=None, hyp_config=None, install_modes=None, install_type=‘bindflash’, oem_key_file=None, output_path=None, pdk_installedpath=‘/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK’, pdk_installpath=None, pdk_runpath=‘/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/pdkinstaller’, platform=None, product=None, run_hostlist=None, run_list=None, sku_num=None, sku_version=None, sudo_pwd=b’dmFsc3lzbGFiMQ==', supported_boards=None, supported_boardtypes=None, supported_hosts=None, supported_os=None, target_config=None, target_os=None, version=‘2.0\n’)
[2019-06-05 13:57:52,387 root DEBUG pdkinstaller 379 2566] Master manifest JSON dump {‘version’: ‘2.0’, ‘input_config’: {‘bind-opts’: , ‘sdk_manifest’: ‘sdk_drivesw_config.json’, ‘hyp_config’: ‘linux’, ‘product_manifests’: [‘hyp71_config.json’], ‘opt-args’: , ‘board_platform’: ‘e3550-t194ab’}, ‘config_name’: ‘Autonomous Vehicle DDP Pegasus Hyperion-7.1 Linux Tegra AB’}
[2019-06-05 13:57:52,387 root INFO pdkinstaller 380 2566] Initializing board and OS configuration to Autonomous Vehicle DDP Pegasus Hyperion-7.1 Linux Tegra AB
[2019-06-05 13:57:52,387 root INFO pdkinstaller 382 2566] Manifest version 2.0
[2019-06-05 13:57:52,387 root DEBUG pdkinstaller 390 2566] product list [‘hyp71_config.json’]
[2019-06-05 13:57:52,387 root DEBUG pdkinstaller 396 2566] target_config sequence linux-hyp71
[2019-06-05 13:57:52,387 root DEBUG pdkinstaller 399 2566] SDK manifest JSON dump {‘version’: ‘2.0’, ‘pdkinstall_config’: {‘envdata’: [{‘value’: ‘Destination Tegra Dominance’, ‘name’: ‘NV_INSTALL_LICENSE_BYPASS’}, {‘value’: ‘YES’, ‘name’: ‘_NV_NON_INTERACTIVE’}], ‘board_mappings’: ‘board_config.json’, ‘platform_type’: ‘t186ref’, ‘supported_hostos’: [‘Ubuntu 16.04 Xenial’, ‘Ubuntu 14.04 Trusty’, ‘Ubuntu 18.04 Bionic’], ‘foundation_runfiles’: [‘foundation-toolchain.run’, ‘foundation-release-sdk.run’, ‘specific.run’], ‘multi_os’: {‘ccc’: [‘linux’, ‘linux-ccc’, ‘qnx’, ‘qnx-ccc’, ‘android’]}, ‘os_map’: [{‘hostfiles’: [], ‘envdata’: [], ‘type’: ‘linux’, ‘runfiles’: [‘linux-oss-minimal-sdk.run’, ‘linux-drive-platform-rootfs.run’, ‘linux-nv-minimal-sdk.run’, ‘linux-initramfs.run’, ‘linux-tegra2aurix_updater.run’, 'drive-t186ref-cuda-.run’, ‘linux-aarch64-tensorrt-.run’, ‘linux-dpx.run’, ‘linux-dds.run’]}, {‘hostfiles’: [], ‘envdata’: [], ‘type’: ‘linux-ccc’, ‘runfiles’: [‘linux-ccc-client-rpi.run’, ‘linux-ccc-client-sdk.run’, ‘linux-ccc-server-sdk.run’]}, {‘hostfiles’: [‘./pdk_extract/drive-t186ref-qnx/qnx_create_targetfs.sh’], ‘envdata’: [{‘name’: ‘QNX_BASE’, ‘path’: ‘’}, {‘name’: ‘QNX_HOST’, ‘path’: ‘’}, {‘name’: ‘QNX_TARGET’, ‘path’: ‘’}, {‘name’: ‘QNX_TOP’, ‘path’: ‘./pdk_extract/drive-t186ref-qnx’}], ‘type’: ‘qnx’, ‘runfiles’: ['-qnx--driver-sdk.run’, '-qnx-early-access.run’, ‘-qnx-cuda-qnx64-native-libs.run’, '-qnx--cuda-qnx-toolkit-libs.run’, ‘-qnx--cudnn-qnx.run’, ‘-qnx--tensorrt-qnx.run’, ‘-qnx--tegra2aurix_updater.run’, ‘-qnx--dds.run’]}, {‘hostfiles’: , ‘envdata’: , ‘type’: ‘qnx-ccc’, ‘runfiles’: [‘-qnx--ccc-server-sdk.run’]}, {‘hostfiles’: , ‘envdata’: , ‘type’: ‘android’, ‘runfiles’: [‘android_custom_install.sh’]}], ‘product_type’: ‘drive’}}
[2019-06-05 13:57:52,387 root DEBUG utilities.py 293 2566] Setting environment data …
[2019-06-05 13:57:52,388 root DEBUG utilities.py 296 2566] Setting environment variable NV_INSTALL_LICENSE_BYPASS to Destination Tegra Dominance
[2019-06-05 13:57:52,388 root DEBUG utilities.py 296 2566] Setting environment variable _NV_NON_INTERACTIVE to YES
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 411 2566] Board manifest JSON dump {‘version’: ‘2.0’, ‘InstallModes’: [‘full’, ‘host’, ‘bind’, ‘flash’, ‘bindflash’, ‘recovery’, ‘reset’, ‘install’, ‘download’], ‘BoardTypes’: [‘ES’, ‘INT’]}
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 414 2566] Supported boards are [‘Ubuntu 16.04 Xenial’, ‘Ubuntu 14.04 Trusty’, ‘Ubuntu 18.04 Bionic’]
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 417 2566] Board types supported … [‘ES’, ‘INT’]
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 419 2566] Install Modes supported … [‘full’, ‘host’, ‘bind’, ‘flash’, ‘bindflash’, ‘recovery’, ‘reset’, ‘install’, ‘download’]
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 467 2566] Using board specific run file specific.run
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 476 2566] Product OS list : [‘linux’, ‘hyp71’]
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 481 2566] Install product config list : [‘linux’, ‘linux-hyp71’]
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: [], ‘envdata’: [], ‘type’: ‘linux’, ‘runfiles’: [‘linux-oss-minimal-sdk.run’, ‘linux-drive-platform-rootfs.run’, ‘linux-nv-minimal-sdk.run’, ‘linux-initramfs.run’, ‘linux-tegra2aurix_updater.run’, 'drive-t186ref-cuda-.run’, ‘linux-aarch64-tensorrt-.run’, ‘linux-dpx.run’, ‘linux-dds.run’]}
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 488 2566] item linux
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 491 2566] runlist_item linux-oss-minimal-sdk.run
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 491 2566] runlist_item linux-drive-platform-rootfs.run
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 491 2566] runlist_item linux-nv-minimal-sdk.run
[2019-06-05 13:57:52,388 root DEBUG pdkinstaller 491 2566] runlist_item linux-initramfs.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 491 2566] runlist_item linux-tegra2aurix_updater.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 491 2566] runlist_item drive-t186ref-cuda-.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 491 2566] runlist_item linux-aarch64-tensorrt-.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 491 2566] runlist_item linux-dpx.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 491 2566] runlist_item linux-dds.run
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 497 2566] env data list : []
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 488 2566] item linux-hyp71
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: [], ‘envdata’: [], ‘type’: ‘linux-ccc’, ‘runfiles’: [‘linux-ccc-client-rpi.run’, ‘linux-ccc-client-sdk.run’, ‘linux-ccc-server-sdk.run’]}
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: [‘./pdk_extract/drive-t186ref-qnx/qnx_create_targetfs.sh’], ‘envdata’: [{‘name’: ‘QNX_BASE’, ‘path’: ‘’}, {‘name’: ‘QNX_HOST’, ‘path’: ‘’}, {‘name’: ‘QNX_TARGET’, ‘path’: ‘’}, {‘name’: ‘QNX_TOP’, ‘path’: ‘./pdk_extract/drive-t186ref-qnx’}], ‘type’: ‘qnx’, ‘runfiles’: ['-qnx--driver-sdk.run’, '-qnx-early-access.run’, ‘-qnx-cuda-qnx64-native-libs.run’, '-qnx--cuda-qnx-toolkit-libs.run’, ‘-qnx--cudnn-qnx.run’, ‘-qnx--tensorrt-qnx.run’, ‘-qnx--tegra2aurix_updater.run’, ‘-qnx--dds.run’]}
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: , ‘envdata’: , ‘type’: ‘qnx-ccc’, ‘runfiles’: [‘-qnx--ccc-server-sdk.run’]}
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: , ‘envdata’: , ‘type’: ‘android’, ‘runfiles’: [‘android_custom_install.sh’]}
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 434 2566] sdk raw foundation runlist = [‘foundation-toolchain.run’, ‘foundation-release-sdk.run’, ‘*specific.run’]
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 435 2566] sdk raw target OS runlist = [‘linux-oss-minimal-sdk.run’, ‘linux-drive-platform-rootfs.run’, ‘linux-nv-minimal-sdk.run’, ‘linux-initramfs.run’, ‘linux-tegra2aurix_updater.run’, ‘drive-t186ref-cuda-.run’, 'linux-aarch64-tensorrt-.run’, ‘linux-dpx.run’, ‘linux-dds.run’]
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 436 2566] sdk host raw runlist =
[2019-06-05 13:57:52,389 root DEBUG pdkinstaller 437 2566] Multi layer SDK/PDK list : [‘hyp71_config.json’]
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 440 2566] Layer hyp71_config.json manifest JSON dump {‘version’: ‘2.0’, ‘pdkinstall_config’: {‘foundation_runfiles’: , ‘multi_os’: {‘ccc’: [‘linux’, ‘linux-ccc’, ‘qnx’, ‘qnx-ccc’, ‘android’]}, ‘os_map’: [{‘hostfiles’: , ‘envdata’: , ‘type’: ‘linux-hyp71’, ‘runfiles’: [‘linux-aarch64-driveav*.run’, ‘linux-aarch64-driveix*.run’, ‘linux-aarch64-drivear*.run’, ‘linux-hyperion-7.1.run’, ‘linux-driveplatform-service*.run’, ‘linux-driveota.run’]}, {‘hostfiles’: [‘./pdk_extract/drive-t186ref-qnx/qnx_create_targetfs.sh’], ‘envdata’: , ‘type’: ‘qnx-hyp71’, ‘runfiles’: [‘qnx-hyperion.run’, ‘qnx-platform.run’]}], ‘envdata’: }}
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 476 2566] Product OS list : [‘linux’, ‘hyp71’]
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 481 2566] Install product config list : [‘linux’, ‘linux-hyp71’]
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: , ‘envdata’: , ‘type’: ‘linux-hyp71’, ‘runfiles’: [‘linux-aarch64-driveav*.run’, ‘linux-aarch64-driveix*.run’, ‘linux-aarch64-drivear*.run’, ‘linux-hyperion-7.1.run’, ‘linux-driveplatform-service*.run’, ‘linux-driveota.run’]}
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 488 2566] item linux
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 488 2566] item linux-hyp71
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-aarch64-driveav*.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-aarch64-driveix*.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-aarch64-drivear*.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-hyperion-7.1.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-driveplatform-service*.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 491 2566] runlist_item linux-driveota.run
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 497 2566] env data list :
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 486 2566] os_item {‘hostfiles’: [‘./pdk_extract/drive-t186ref-qnx/qnx_create_targetfs.sh’], ‘envdata’: , ‘type’: ‘qnx-hyp71’, ‘runfiles’: [‘qnx-hyperion.run’, ‘qnx-platform.run’]}
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 442 2566] Layer config hyp71_config.json raw Foundation runlist = [‘foundation-toolchain.run’, ‘foundation-release-sdk.run’, ‘*specific.run’]
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 443 2566] Layer config hyp71_config.json raw OS runlist = [‘linux-oss-minimal-sdk.run’, ‘linux-drive-platform-rootfs.run’, ‘linux-nv-minimal-sdk.run’, ‘linux-initramfs.run’, ‘linux-tegra2aurix_updater.run’, ‘drive-t186ref-cuda-.run’, 'linux-aarch64-tensorrt-.run’, ‘linux-dpx.run’, ‘linux-dds.run’, ‘linux-aarch64-driveav*.run’, ‘linux-aarch64-driveix*.run’, ‘linux-aarch64-drivear*.run’, ‘linux-hyperion-7.1.run’, ‘linux-driveplatform-service*.run’, ‘linux-driveota.run’]
[2019-06-05 13:57:52,390 root DEBUG pdkinstaller 444 2566] Layer config hyp71_config.json host raw runlist =
[2019-06-05 13:57:52,391 root DEBUG pdkinstaller 445 2566] Layer config hyp71_config.json env data list =
[2019-06-05 13:57:52,391 root DEBUG pdkinstaller 450 2566] Full sdk/pdk raw target install list = [‘foundation-toolchain.run’, ‘foundation-release-sdk.run’, ‘specific.run’, ‘linux-oss-minimal-sdk.run’, ‘linux-drive-platform-rootfs.run’, ‘linux-nv-minimal-sdk.run’, ‘linux-initramfs.run’, ‘linux-tegra2aurix_updater.run’, 'drive-t186ref-cuda-.run’, ‘linux-aarch64-tensorrt-.run’, ‘linux-dpx.run’, ‘linux-dds.run’, 'linux-aarch64-driveav.run’, ‘linux-aarch64-driveix*.run’, ‘linux-aarch64-drivear*.run’, ‘linux-hyperion-7.1.run’, ‘linux-driveplatform-service*.run’, ‘linux-driveota.run’]
[2019-06-05 13:57:52,391 root DEBUG pdkinstaller 451 2566] Full sdk/pdk host side install list =
[2019-06-05 13:57:52,394 root DEBUG pdk_bind.py 77 2566] InfoROM supported boards [‘e3550’]
[2019-06-05 13:57:52,410 root INFO port_identifier.py 41 2566] Processor found in ttyUSB3
[2019-06-05 13:57:52,410 root INFO pdk_bind.py 85 2566] Aurix port /dev/ttyUSB3 found. Fetching board revision from InfoROM …
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 80 2566] pcbrevision_offset- 68 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 81 2566] pcbrevision_size- 2 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 82 2566] min_Inforom_version- 2 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 83 2566] supported_Inforom_version- 3 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 84 2566] Inforom_version_size- 1 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 85 2566] Inforom_version_offset- 35 :
[2019-06-05 13:57:52,410 root DEBUG inforom_data_handler.py 103 2566] In get_Inforom_dump()
[2019-06-05 13:57:52,412 root DEBUG utilities.py 311 2566] Spawning child process with args [‘/usr/bin/sudo’, ‘chmod’, ‘777’, ‘/dev/ttyUSB3’]
[2019-06-05 13:57:52,414 root DEBUG consoleskip_logger.py 16 2566] b’[host] [sudo] password for lab: ’
[2019-06-05 13:57:52,516 root DEBUG consoleskip_logger.py 16 2566] b’\r\n’
[2019-06-05 13:57:54,122 root DEBUG consoleskip_logger.py 16 2566] b’Sorry, try again.\r\n’
[2019-06-05 13:57:54,123 root DEBUG consoleskip_logger.py 16 2566] b’[host] [sudo] password for lab: ’
[2019-06-05 13:57:54,173 root DEBUG consoleskip_logger.py 16 2566] b’\r\n’
[2019-06-05 13:57:54,280 root DEBUG inforom_data_handler.py 110 2566] Aurix port /dev/ttyUSB3 is open
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] inforom dump
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] Info: Executing cmd: inforom, argc: 1, args: dump
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 4D 4F 52 02 00 20 00 C5 FF FF
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 18 12 18 20 53 59 53 20 00 4B
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 57 52 C0 00 FF FF FF FF FF FF
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] FF FF 53 59 53 03 00 A0 00 51
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 18 12 18 20 30 30 31 2D 30 30
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 30 32 2D 30 35 35 33 36 2D 30
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 34 39 00 00 00 00 00 00 03 42
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 58 00 34 36 36 31 53 2D 33 30
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 42 2D 30 35 35 33 45 00 00 00
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 11 09 BF CB 4B 04 00 00 00 07
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] BF CB 4B 04 00 00 00 08 BF CB
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 4B 04 00 00 00 0A BF CB 4B 04
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 00 00 00 0B BF CB 4B 04 00 00
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] 00 0C BF CB 4B 04 00 00 00 0D
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] BF CB 4B 04 00 00 00 44 00 FF
[2019-06-05 13:58:00,390 root DEBUG inforom_data_handler.py 119 2566] FF FF FF FF FF FF FF FF FF FF
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] FF FF FF FF FF FF FF FF FF FF
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] FF FF 4B 57 52 01 00 20 00 59
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] 00 00 00 00 00 00 00 00 00 00
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] 00 00 00 00 00 00 53 45 FF FF
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] Command Executed
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 119 2566] shell>
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 128 2566] closed successfully
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 141 2566] In get_Target_uniqueId()
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 142 2566] Inforom data length: 224
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 153 2566] Found InfoROM header : ROM
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 161 2566] version data : 3
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 172 2566] InfoROM version is 3
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 182 2566] skuinfo_str : 940-63550-2000-100
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 187 2566] pcbrevision_str : b03
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 88 2566] sku- {‘e3550’: {‘b02’: ‘b03’}} :
[2019-06-05 13:58:00,391 root DEBUG inforom_data_handler.py 94 2566] PCB revision : b03 :
[2019-06-05 13:58:00,391 root INFO pdk_bind.py 88 2566] Board PCB revision is b03
[2019-06-05 13:58:00,399 root DEBUG utilities.py 111 2566] Created new temporary directory: /tmp/pdkinstall-tmp-dw0ikjda-bind
[2019-06-05 13:58:00,416 root DEBUG pdk_bind.py 41 2566] target SOC is t194
[2019-06-05 13:58:00,416 root DEBUG pdk_bind.py 41 2566] rm -rf /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux/pct.json /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont0.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont0.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont1.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont1.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont2.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont2.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont3.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont3.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont4.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont4.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont5.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont5.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont6.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont6.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont7.img /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a/cont7.dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a
[2019-06-05 13:58:00,417 root DEBUG pdk_bind.py 124 2566] Applying additional Bind opts
[2019-06-05 13:58:00,417 root INFO pdk_bind.py 128 2566] Executing bind cmd make -f Makefile.bind PCT=linux BOARD=e3550b03-t194a
[2019-06-05 13:58:02,304 root DEBUG pdk_bind.py 41 2566] target SOC is t194
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] mkdir -p /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/out/e3550b03-t194a
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] touch /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a//pct
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] make -C /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/ PCT=linux CROSS_COMPILE=/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] O=/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux/ HYP_SRC=“/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x”
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] PCT_INC=“/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct”
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] SOC_PCT_INC=“/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc”
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] BUILD_DTB_DTC=/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] HARDWARE_DIR=“/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia”
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] make[1]: Entering directory ‘/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a’
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] mkdir -p /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux/
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MM -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.o pct.c
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -c pct.c -o /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.o
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.o -nostdlib -Tpct.ld -o /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.elf
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-objcopy -j .conf -O binary /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.elf /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct.bin
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] gcc -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MM -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct_mem.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct_mem pct_mem.c
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] gcc -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av pct_mem.c -o /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct_mem
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct_mem > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//pct_mem.txt
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] cp -f linux/.cfg /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux/
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/common/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts/common -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/sim/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dts0.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dts0 drive_av//t194-debug-server.dts > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dts0
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] printf “\ndrive_av//t194-debug-server.dts:” >> /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dts0.d
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dts0 > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-debug-server.dtb
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D QNX -MMD -MP -x assembler-with-cpp -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/common/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts/common -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/sim/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dts0.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dts0 drive_av//t194-comms-service.dts > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dts0
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] printf “\ndrive_av//t194-comms-service.dts:” >> /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dts0.d
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dts0 > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-comms-service.dtb
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D QNX -MMD -MP -x assembler-with-cpp -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/common/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts/common -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/sim/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dts0.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dts0 drive_av//t194-security-service.dts > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dts0
[2019-06-05 13:58:02,305 root DEBUG pdk_bind.py 41 2566] printf “\ndrive_av//t194-security-service.dts:” >> /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dts0.d
[2019-06-05 13:58:02,306 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dts0 > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service.dtb
[2019-06-05 13:58:02,306 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D QNX -MMD -MP -x assembler-with-cpp -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/common/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts/common -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/sim/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I./drive_av -MF /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dts0.d -MT /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dts0 drive_av//t194-security-service-cs.dts > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dts0
[2019-06-05 13:58:02,306 root DEBUG pdk_bind.py 41 2566] printf “\ndrive_av//t194-security-service-cs.dts:” >> /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dts0.d
[2019-06-05 13:58:02,306 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dts0 > /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t19x/configs/t194ref-release/pct/e3550b03-t194a/linux//t194-security-service-cs.dtb
[2019-06-05 13:58:02,306 root DEBUG pdk_bind.py 41 2566] /home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/common/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/automotive/kernel-dts/common -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t19x/sim/kernel-dts -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/…/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/e3550b03-t194a/dtb_include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t19x/kernel-include -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -DPLATFORM_XA -DENABLE_BPMP_SERVER -DGID_BPMP_SERVER=6 -DBPMP_SERVER=64 -DBPMP_IMAGE_BUFFER="cont0.img" -DBPMP_DTB_BUFFER="cont0.dtb" -DENABLE_VM_SERVER -DENABLE_AUDIO_SERVER -DGID_VM_SERVER=7 -DVM_SERVER=128 -DRM_IMAGE_BUFFER="cont1.img" -DRM_DTB_BUFFER="cont1.dtb" -DENABLE_WDT_SERVER -DGID_WDT_SERVER=8 -DWDT_SERVER=256 -DWDT_IMAGE_BUFFER="cont2.img" -DWDT_DTB_BUFFER="cont2.dtb" -DENABLE_SYSMGR_SERVER -DGID_SYSMGR_SERVER=9 -DSYSMGR_SERVER=512 -DSYSMGR_IMAGE_BUFFER="cont3.img" -DSYSMGR_DTB_BUFFER="cont3.dtb" -DENABLE_VSC_EMMC_VIRT -DENABLE_VSC_UFS_VIRT -DENABLE_VSC_QSPI0_VIRT -DENABLE_VSC_SERVER -DGID_VSC_SERVER=10 -DVSC_SERVER=1024 -DVSC_IMAGE_BUFFER="cont4.img" -DVSC_DTB_BUFFER="cont4.dtb" -DENABLE_SE_SERVER -DGID_SE_SERVER=11 -DSE_SERVER=2048 -DSE_IMAGE_BUFFER="cont5.img" -DSE_DTB_BUFFER="cont5.dtb" -DENABLE_DEBUG_SERVER -DGID_DEBUG_SERVER=12 -DDEBUG_SERVER=4096 -DDEBUG_IMAGE_BUFFER="cont6.img" -DDEBUG_DTB_BUFFER="cont6.dtb" -DENABLE_TZ_SERVER -DGID_TZ_SERVER=13 -DTZ_SERVER=8192 -DTZ_IMAGE_BUFFER="cont7.img" -DTZ_DTB_BUFFER="cont7.dtb" -DNR_SERVERS=8 -I./linux/ -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9.0_Linux_hyperion_E3550/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/lab/nvidia/nvidia_sdk/DRIVE_Software_9
