hi!
I am trying to run sdkmanager to install on drive px2. The process ends after Step 3 while flashing. failure ! i am not why ?:
@1. host system: 16.04.
@2. flash target Hardware AutoChauffeur
@3. this is terminal log info only flash.
17:23:06 INFO : Flash Dual Tegras in Parallel : Using LegacyInstaller to install NV_FLASH_DUAL_TEGRAS_IN_PARALLEL_COMP
17:23:06 INFO : Flash Dual Tegras in Parallel : user
17:23:06 INFO : Flash Dual Tegras in Parallel : exec_command: sudo rm -f /var/lock/LCK…ttyUSB1
17:23:06 INFO : Flash Dual Tegras in Parallel : exec_command: sudo rm -f /var/lock/LCK…bootburn_seq
17:23:06 INFO : Flash Dual Tegras in Parallel : exec_command: ./pdk_flash.sh -b p2379c01-t186
17:23:06 INFO : Flash Dual Tegras in Parallel : p2379c01-t186 will be flashed
17:23:06 INFO : Flash Dual Tegras in Parallel : linux will be flashed
17:23:06 INFO : Flash Dual Tegras in Parallel : Make sure only one target is connected to USB
17:23:06 INFO : Flash Dual Tegras in Parallel : and Aurix port is not open in minicom or another terminal
17:23:06 INFO : Flash Dual Tegras in Parallel : +++++++++++++++++++++++++++++++++++++++++++++++++
17:23:06 INFO : Flash Dual Tegras in Parallel : make -f Makefile.bind BOARD=p2379c01-t186 PCT=linux >>>>>>
17:23:06 INFO : Flash Dual Tegras in Parallel : target SOC is t186
17:23:06 INFO : Flash Dual Tegras in Parallel : rm -rf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.json /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
17:23:06 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
17:23:06 INFO : Flash Dual Tegras in Parallel : make -C /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/ PCT=linux CROSS_COMPILE=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-
17:23:06 INFO : Flash Dual Tegras in Parallel : O=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/ HYP_SRC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x”
17:23:06 INFO : Flash Dual Tegras in Parallel : PCT_INC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct”
17:23:06 INFO : Flash Dual Tegras in Parallel : SOC_PCT_INC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc”
17:23:06 INFO : Flash Dual Tegras in Parallel : BUILD_DTB_DTC=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc
17:23:06 INFO : Flash Dual Tegras in Parallel : HARDWARE_DIR=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia”
17:23:06 INFO : Flash Dual Tegras in Parallel : make[1]: Entering directory ‘/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a’
17:23:06 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
17:23:06 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o pct.c
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -c pct.c -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o -nostdlib -Tpct.ld -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-objcopy -j .conf -O binary /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.bin
17:23:07 INFO : Flash Dual Tegras in Parallel : gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem pct_mem.c
17:23:07 INFO : Flash Dual Tegras in Parallel : gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm pct_mem.c -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.txt
17:23:07 INFO : Flash Dual Tegras in Parallel : cp -f linux/.cfg /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 linux/…/single_vm//t186-i2c-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0
17:23:07 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-i2c-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dtb
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 linux/…/single_vm//t186-vsc-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0
17:23:07 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-vsc-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dtb
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0 linux/…/single_vm//t186-bpmp-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0
17:23:07 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-bpmp-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0.d
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dtb
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dts0 linux/…/single_vm//t186-sysmgr-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dts0
17:23:07 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-sysmgr-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dts0.d
17:23:07 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-sysmgr-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dts0 linux/…/single_vm//t186-monitor-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dts0
17:23:08 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-monitor-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dts0.d
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-monitor-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dts0 linux/…/single_vm//t186-se-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dts0
17:23:08 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-se-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dts0.d
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-se-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D QNX -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dts0 linux/…/single_vm//t186-vm-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dts0
17:23:08 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-vm-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dts0.d
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vm-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : make[1]: Leaving directory ‘/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186a’
17:23:08 INFO : Flash Dual Tegras in Parallel : cp /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct_mem.txt /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
17:23:08 INFO : Flash Dual Tegras in Parallel : rm -f /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/.cfg
17:23:08 INFO : Flash Dual Tegras in Parallel : cp -f /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/.cfg /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a
17:23:08 INFO : Flash Dual Tegras in Parallel : rm -f /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/bpmp-server/bpmp-server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-bpmp-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/kernel_vm_server/vmserver.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-vm-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/monitor/monitor-server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-monitor-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/i2c/i2c-server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-i2c-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/system_manager/sysmgr-server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-sysmgr-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/vm-server/se/se-server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img
17:23:08 INFO : Flash Dual Tegras in Parallel : echo " LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb"
17:23:08 INFO : Flash Dual Tegras in Parallel : LN /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -sf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/t186-se-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob
17:23:08 INFO : Flash Dual Tegras in Parallel : cp /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/sidekick.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/debug_server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/tz_server.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/dtb/t186ref-server.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/firmwares/bin/t186/part_loader.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont0.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont1.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont2.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont3.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont4.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/cont5.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob
17:23:08 INFO : Flash Dual Tegras in Parallel : (cd /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob; find | cpio -oL -H newc > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob.cpio)
17:23:08 ERROR : Flash Dual Tegras in Parallel : 18955 blocks
17:23:08 INFO : Flash Dual Tegras in Parallel : rm -rf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/tools/t18x/pctdump_x86/pctdump /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.bin -json > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.json
17:23:08 INFO : Flash Dual Tegras in Parallel : # Below symlink is for compatibility w/ System Profiler
17:23:08 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/hypervisor/configs/t186ref-release/pct/linux
17:23:08 INFO : Flash Dual Tegras in Parallel : rm -rf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/hypervisor/configs/t186ref-release/pct/linux/pct.json
17:23:08 INFO : Flash Dual Tegras in Parallel : ln -rs /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.json
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/hypervisor/configs/t186ref-release/pct/linux/pct.json
17:23:08 INFO : Flash Dual Tegras in Parallel : cat /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/pctvmm.bin /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/blob.cpio > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186a/Image
17:23:08 INFO : Flash Dual Tegras in Parallel : target SOC is t186
17:23:08 INFO : Flash Dual Tegras in Parallel : rm -rf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/pct.json /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont0.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont0.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont1.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont1.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont2.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont2.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont3.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont3.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont4.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont4.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont5.img /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b/cont5.dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b
17:23:08 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/out/p2379c01-t186b
17:23:08 INFO : Flash Dual Tegras in Parallel : make -C /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/ PCT=linux CROSS_COMPILE=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-
17:23:08 INFO : Flash Dual Tegras in Parallel : O=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/ HYP_SRC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x”
17:23:08 INFO : Flash Dual Tegras in Parallel : PCT_INC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct”
17:23:08 INFO : Flash Dual Tegras in Parallel : SOC_PCT_INC=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc”
17:23:08 INFO : Flash Dual Tegras in Parallel : BUILD_DTB_DTC=/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc
17:23:08 INFO : Flash Dual Tegras in Parallel : HARDWARE_DIR=“/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia”
17:23:08 INFO : Flash Dual Tegras in Parallel : make[1]: Entering directory ‘/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b’
17:23:08 INFO : Flash Dual Tegras in Parallel : mkdir -p /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o pct.c
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -c pct.c -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.o -nostdlib -Tpct.ld -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-objcopy -j .conf -O binary /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.elf /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct.bin
17:23:08 INFO : Flash Dual Tegras in Parallel : gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MM -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem pct_mem.c
17:23:08 INFO : Flash Dual Tegras in Parallel : gcc -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm pct_mem.c -o /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//pct_mem.txt
17:23:08 INFO : Flash Dual Tegras in Parallel : cp -f linux/.cfg* /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux/
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 linux/…/single_vm//t186-i2c-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0
17:23:08 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-i2c-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0.d
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-i2c-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 linux/…/single_vm//t186-vsc-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0
17:23:08 INFO : Flash Dual Tegras in Parallel : printf “\nlinux/…/single_vm//t186-vsc-server.dts:” >> /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0.d
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/tools/host/dtc/dtc -I dts -O dtb /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dts0 > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-vsc-server.dtb
17:23:08 INFO : Flash Dual Tegras in Parallel : /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/toolchains/tegra-4.9-nv/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc -E -D LK -MMD -MP -x assembler-with-cpp -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/vcm/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/t18x/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/t18x/common/kernel-dts -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/…/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/p2379c01-t186b/dtb_include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/platform/tegra/common/kernel-dts -P -I./linux/ -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/virt/libvirt/include/pct -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/pct/soc -I -ffreestanding -I/home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/platform-config/hardware/nvidia/soc/tegra/kernel-include -I./single_vm -MF /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0.d -MT /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux//t186-bpmp-server.dts0 linux/…/single_vm//t186-bpmp-server.dts > /home/user/nvidia/nvidia_sdk/DRIVE/Linux/5.0.10.3/OS/DriveSDK/drive-t186ref-foundation/virtualization/hypervisor/t18x/configs/t186ref-release/pct/linux
Hi lxjia,
Could you please refer to the following link for your topic to see if can help?
Dear lxjia,
Are you able to flash the board now? Can you please share your status
I’m so sorry for this question, i guess i have lost my work.and my buddy try to falsh px2 SDK, he get successe. strangely
i don’t why , i try your means that always failure, thanks all
