Here’s my following info:
Hardware Platform: [DRIVE AGX Xavier™ Developer Kit]
Software Version: [DRIVE Software 9]
Host Machine Version: [Ubuntu 18.04]
SDK Manager Version: [Example: 1.3.1.7110]
I am currently going through the steps to flash my target system (Drive AGX Xavier) and upon “Step 3” which is Setup Process, I get an error about Docker and this ultimately leads to the flashing process failing. I am trying to accomplish flashing my target system to Ubuntu 18.04 with Drive Software 10.
The error is as follows:
INFO: Drive Platform Targetfs: start to download...
Drive Platform Targetfs: ERROR: The docker failed to properly install the components
Error response from daemon: Get https://registry-1.docker.io/v2/: dial tcp 23.22.155.84:443: connect: connection refused.
ERROR: Drive Platform Targetfs: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh;
[error]:
ERROR: Drive Platform Targetfs: command terminated with error
SUMMARY: Drive Platform Targetfs: Failed to execute commands with GenericInstaller
Drive Platform Targetfs: W: Target Sources (restricted/sources/Sources) is configured multiple times in /etc/apt/sources.list:2 and /etc/apt/sources.list:7
Drive Platform Targetfs: Reading package lists...
Drive Platform Targetfs: Unable to find image 'hello-world:latest' locally
Drive Platform Targetfs: Sending build context to Docker daemon 54.22kb
As you can see there is a bunch of errors with docker and some warnings and thus the installation failed in SDK manager on the host-PC. Please provide any assistance. Thank you!
Cordially,
Brendan Sting
