Error installing SDK Manager 1.3.1.7110
there are errors installing SDK Manager on AGX Drive:
18:46:52 ERROR: OSS and NV packages: /tmp/resolvconf.config.8HvZSF: 13: /tmp/resolvconf.config.8HvZSF: ifquery: not found
18:46:53 ERROR: OSS and NV packages: /tmp/resolvconf.config.8HvZSF: 13: /tmp/resolvconf.config.8HvZSF: ifquery: not found
18:52:18 INFO: Drive Platform Targetfs: docker: Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers).
19:08:32 INFO: Drive Platform Targetfs: ERROR: could not build docker image
19:08:32 INFO: Drive Platform Targetfs: INFO: Removing the docker image(s) that was just created
19:08:32 INFO: Drive Platform Targetfs: Total reclaimed space: 0B
19:08:32 INFO: Drive Platform Targetfs: ERROR: The docker failed to properly install the components
19:08:32 INFO: Drive Platform Targetfs: Time to failure: 0 minutes and 45 seconds
19:08:32 INFO: Drive Platform Targetfs: [ Package Install Finished with Error ]
19:08:32 ERROR: Drive Platform Targetfs: [error]: : [exec_command]: /bin/bash -c /tmp/XXXXX/tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh; [error]:
19:08:32 ERROR: Drive Platform Targetfs: command terminated with error
19:08:32 SUMMARY: Drive Platform Targetfs: Failed to execute commands with GenericInstaller
19:08:32 SUMMARY: Flash Xavier A+B in parallel: Depends on failed component
19:08:32 SUMMARY: Drive Platform Targetfs Patch: Depends on failed component
Does anybody knows some help?
Thank you
Moving this topic to the correct forum for better coverage.
Hi @andreas.schwager,
Please download the latest SDK Manager (1.3.1 as of now) via below link and try with it. Thanks!
https://developer.nvidia.com/nvsdk-manager
Please help to vote if camera bundled in the devkit is important or useful to you in some way or you rather have no camera by default. Thanks!
Dear VickNV,
sorry, there was a typo on my side. The version I installed is SDK Manager 1.3.1.7110.
I expect this to be the latest one.
Please help to update your topic title with the correct version and refer to below topic for your issue. Thanks!
Is this issue caused by the AGX Drive or by the host machine?
Is it recommended to perform the SDK manager installations again using another host machine?
Dear @andreas.schwager,
Yes. Trying from an another fresh installed host would resolve issues related to current host state and confirms if it is actually an issue with DRIVE platform.
Dear VickNV,
how to change the title of my post from “error-installing-sdk-manager-1-2-1-7110” to “error-installing-sdk-manager-1-3-1-7110” ?
I can’t edit this!
as
Sorry that I didn’t know you cannot update it. I just updated it for you.
there is another one:
sdkmanager says:
error: NV_DRIVE_PLATFORM_RFS_TARGET_COMP@DDPX: [error]: : [exec_command]: /bin/bash -c /tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh; [error]:
if executing “/bin/bash -c /tmp_NV_DRIVE_PLATFORM_RFS_TARGET_COMP.sh;” on shell:
Step 3/4 : RUN apt-get update && apt-get install --yes apt-utils && apt-get install --yes python3 python3-dev qemu-user-static && apt-get autoremove --yes && apt-get clean
—> Running in d513682c6bf7
Err:1 Index of /ubuntu bionic InRelease
Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out
Err:2 Index of /ubuntu bionic-updates InRelease
Unable to connect to archive.ubuntu.com:http:
Err:3 Index of /ubuntu bionic-backports InRelease
Err:4 Index of /ubuntu bionic-security InRelease
Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.1
89.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
Reading package lists…
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic/InRelease Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.1
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-updates/InRelease Unable to connect to archive.ubuntu.com:http:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-backports/InRelease Unable to connect to archive.ubuntu.com:http:
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/InRelease Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80
(91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree…
Reading state information…
Package apt-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
apt
E: Package ‘apt-utils’ has no installation candidate
The command ‘/bin/sh -c apt-get update && apt-get install --yes apt-utils && apt-get install --yes python3 python3-dev qemu-user-static && apt-get autoremove --yes && apt-get clean’ returned a non
-zero code: 100
Time to failure: 0 minutes and 56 seconds
Has anybody seen this before?
Please see if any topics below helps. Searching in the forum is always a good way to leverage others’ experience. Thanks!
