• Hardware Platform (Jetson)
• DeepStream Version 6.0
• JetPack Version (4.6.2)
• VPI Version (1.2)
• Issue Type( questions)
Hello everyone,
I am currently developing an application which utilizes DeepStream with the following pipeline: NvArgus with buf-api=True
(producing NvBufSurface
) → nvvideoconvert
to RGBA → rectifying surface using VPI’s EGL interoperability. The workflow is NvBufSurface (input) -> remap -> DeviceMemory (VPI's CUDA interoperability) (output)
. Then, I generate a disparity map from the rectified images using vpiSubmitStereoDisparityEstimator
Now, I want to perform the remap fully on surface memory (NvBufSurface -> remap -> NvBufSurface
). However, the application throws an exception ('terminate called after throwing an instance of ‘std::runtime_error’ what(): VPI_ERROR_INTERNAL: Can’t perform shared mapping), when converting the surface memory to grayscale using vpiSubmitConvertImageFormat
How should I configure the VPIConvertImageFormatParams
to make this possible? Are there any concerns with my approach?
