@adolfotregosa , I swapped my use of the reboot=pci kernal parameter for your suggestion of nvidia-modeset.hdmi_deepcolor=0, and then rebooted the Linux install two time to allow for the effect to propagate through the entire boot cycle.
Delightfully, it does seem to resolve the aforementioned boot menu display issue, without the need to cold reset, i.e. resorting to PCI “reboot”. When inspecting the VRR Information via the LG TV’s info diologe popup:
https://www.lg.com/ca_en/support/product-support/troubleshoot/help-library/cs-CT52001643-20153165982189/?srsltid=AfmBOorlSVrIf_UEo-vNl-zokf6w7akd7eTdn8wV9KUWwp4pXDTErz1N
The results over the course of the second boot up cycle are:
BIOS UEFI Menu
VRR Information
- 60Hz
- FIXED
- 3840 x 2160P@60
- RGB 8b TM SDR
Kernel startup TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 8b TM SDR
SDDM Login Menu
VRR Information
- 118.68Hz
- VRR
- 3840 x 2160P@120
- RGB 8b 4L8 SDR
User login TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 8b TM SDR
KDE Plasma desktop
VRR Information
- 118.68Hz
- VRR
- 3840 x 2160P@120
- RGB 8b 4L8 HDR10
Kernel shutdown TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 8b TM HDR10
reboot=pci
BIOS UEFI Menu
VRR Information
- 60Hz
- FIXED
- 3840 x 2160P@60
- RGB 8b TM SDR
Kernel startup TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 10b 4L6 SDR
SDDM Login Menu
VRR Information
- 118.68Hz
- VRR
- 3840 x 2160P@120
- RGB 10b 4L10 SDR
User login TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 10b 4L6 SDR
KDE Plasma desktop
VRR Information
- 118.68Hz
- VRR
- 3840 x 2160P@120
- RGB 10b 4L10 HDR10
Kernel shutdown TTY
VRR Information
- 59.39Hz
- VRR
- 3840 x 2160P@60
- RGB 10b 4L6 SDR
Might I ask @adolfotregosa, why disabling the nvidia modset for hdmi_deepcolor properly transitions 4L8 to TM ? I’d still appreciate being able to take full advantage of 10bit.
FYI, addtional info about the test system:
Operating System: NixOS 24.11
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.8.0
Qt Version: 6.8.3
Kernel Version: 6.12.28 (64-bit)
Graphics Platform: Wayland
Processors: 32 × Intel® Core™ i9-14900K
Memory: 188.4 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 4090/PCIe/SSE2
Manufacturer: ASUS
